04 mazda 6 alarm wiring and tach wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55098
Printed Date: April 24, 2024 at 10:55 PM
Topic: 04 mazda 6 alarm wiring and tach wire
Posted By: leftyrev
Subject: 04 mazda 6 alarm wiring and tach wire
Date Posted: May 03, 2005 at 10:42 PM
looking for alarm wiring for a 04 mazda6 also looking for tach wire  , thanks
Posted By: thepencil
Date Posted: May 04, 2005 at 12:59 PM
DIRECTWIRE™ WIRING INFORMATION - MAZDA / 6 / 2004 / Remote Start
12volts black (40A), BLACK/ yel (30A)   +   ignition harness
Starter BLACK/ blue   +   ignition harness
Second Starter N/A
Ignition blue   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red   +   ignition harness
Second Accessory BLACK/ white   +   ignition harness
Keysense WHITE/ blue   +   ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Power Lock lt. green   -   driver kick or door lock module
Notes: Lock is negative trigger thru a 1000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
The door lock control module is located above the passenger kick panel.
Power Unlock same as power lock wire
Lock Motor RED / blue   5wi driver kick or door lock module
Notes: The door lock control module is located above the passenger kick panel.
Unlock Motor RED / green   5wi driver kick or door lock module
Parking Lights+ lt. GREEN/ black   +   driver kick, 14 pin plug
Parking Lights- RED / white   -   headlight switch
Hazards blue/orange   -   switch or door lock module
Turn Signal(L) WHITE/ black   +   turn signal switch
Turn Signal(R) WHITE/ red   +   turn signal switch
Reverse Light RED / yellow   +   driver kick, 14 pin plug
Door Trigger GREEN/ orange   -   driver kick or door lock module
Dome Supervision yellow/black   -   driver kick or door lock module
Trunk/Hatch Pin brown   -   driver kick or door lock module
Hood Pin gray/red   -   pin switch or theft module
Notes: The theft-deterrent control module is located in the center console.
Trunk/Hatch Release yellow   -   switch or door lock module
Power Sliding Door N/A
Factory Alarm Arm blue   -   driver kick or door lock module
Notes: Arm is negative trigger thru a 1000 ohm resistor. Disarm is a straight negative trigger. MUST use relays.
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock use key sense wire
Tachometer NOT blk/wht or grn/stripe   ac   any ignition coil or coil pack
Notes: On the 4 cyl models use the wire that is NOT BLACK/ white. On the 6 cyl models use the wire that is NOT GREEN/ stripe.
Wait to start N/A
Brake Wire GREEN/ YELLOW   +   brake pedal switch
Parking Brake brown   -   parking brake switch
Horn Trigger PURPLE / white   -   switch or door lock module
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: leftyrev
Date Posted: May 04, 2005 at 3:33 PM
Thanks , I really apreciate it
