DIRECTWIRE™ WIRING INFORMATION - NISSAN / FRONTIER / 2005 / Remote Start
12volts green (40A) + ignition harness
Starter gray + ignition harness
Second Starter lt. green + ignition harness
Ignition WHITE/ green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red + ignition harness
Second Accessory GREEN/ YELLOW + ignition harness
Keysense black + ignition harness or BCM, pin 37
Notes: The BCM (Body Control Module) is to the right of the steering column.
Power Lock lt. green to purple - driver kick or BCM, pin 45
Power Unlock white to lt. green - driver kick or BCM, pin 46
Lock Motor purple 5wi driver kick or BCM, pin 65
Unlock Motor gray 5wi driver kick or BCM, pin 59
Parking Lights+ gray + driver kick, harness to rear
Parking Lights- N/A
Hazards green - hazard switch or BCM, pin 29
Turn Signal(L) lt. green + driver kick or BCM, pin 60
Turn Signal(R) green + passenger kick or BCM, pin 61
Reverse Light lt. blue + driver kick, harness to rear
Door Trigger see notes - BCM
Notes: The LF door is gray in pin 47. The RF door is lt. green in pin 12. The LR door is pink in pin 48. The RR door is blue in pin 13. Use all four wires and diode isolate each.
Dome Supervision brown - driver A pillar or BCM, pin 63
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm lt. blue - driver kick or BCM, pin 8
Notes: Meter this wire while turning the key in the driver door key cylinder. This wire will also lock the doors.
Factory Alarm Disarm RED / white to gray - driver kick or BCM, pin 7
Notes: Meter this wire while turning the key in the driver door key cylinder. This wire will also unlock the doors with a double pulse.
Disarm No Unlock
Tachometer NOT WHITE/ green ac any fuel injector
Wait to start N/A
Brake Wire yellow + brake pedal switch or driver kick
Parking Brake green - parking brake sw. or cluster, pin 31
Horn Trigger brown - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Not Available
Be careful whose advice you buy, but be patient with those who supply it.
