04 Element - Can’t find tach wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55409
Printed Date: May 05, 2024 at 5:58 AM
Topic: 04 Element - Can’t find tach wire
Posted By: elementowner6
Subject: 04 Element - Can’t find tach wire
Date Posted: May 09, 2005 at 10:10 AM
I have a 2004 Honda element EX and I have installed a Viper 690VX alarm/remote start.   Everything went fine, even the immobilizer bypass.  However I have it setup right now for voltage detection because I drove myself crazy looking for the tach wire.  The wiring guides say that there is a single wire tach test connector next to the battery that should be blue/white or blue/silver.  The only connector I have seen near there is the one for the fog lights.  Has anyone else found this wire?  I don't want to pull it directly off the plugs which was something someone suggested to me.
-Elementowner6
Posted By: thepencil
Date Posted: May 09, 2005 at 11:07 AM
Tachometer blue   ac   ECM/PCM behind glovebox, pin E25
DIRECTWIRE™ WIRING INFORMATION - HONDA / ELEMENT / 2004 / Remote Start
[PRINT THIS PAGE]
12volts white (50A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter N/A
Ignition BLACK / YELLOW   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red   +   ignition harness
Second Accessory WHITE/ red   +   ignition harness
Keysense RED / white   -   ign harn or factory alarm plug
Notes: The factory alarm plug is a green plug to the left of the steering column.
Power Lock WHITE/ blue   -   driver kick, door harness
Power Unlock WHITE/ green   -   driver kick, door harness
Lock Motor yellow/black   5wi DKP or back of fuse box, top left
Unlock Motor YELLOW /GREEN   5wi DKP or back of fuse box, top left
Parking Lights+ RED / black   +   back of fuse box, top middle
Notes: Can also use RED / yellow (+) at the front of the fuse box, 18 pin plug, pin 15.
Parking Lights- blue   -   switch or factory alarm plug
Hazards same as turn signal wires
Turn Signal(L) GREEN/ red   +   turn signal switch
Turn Signal(R) GREEN/ YELLOW   +   turn signal switch
Reverse Light GREEN/ black   +   frt of fuse box, 18 pin plug, pin 1
Door Trigger green (D), gray/black (P)   -   frt of fusebox or factory alarm plug
Notes: Use both wires and diode isolate each.
Dome Supervision GREEN/ red   -   back of fuse box, top right
Trunk/Hatch Pin red   -   frt of fusebox or factory alarm plug
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Wait to start N/A
Brake Wire WHITE/ black   +   brake pedal switch
Parking Brake GREEN/ orange   -   Immobilizer Control Unit, pin 4
Notes: The Immobilizer Control Unit is on the ignition key cylinder.
Horn Trigger orange   -   switch or factory alarm plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Required:
Yes Type:
Transponder
Part #: 555i, 556U, or 555U
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: KarTuneMan
Date Posted: May 09, 2005 at 12:02 PM
ALSO....blue with 2 silver dots, into the drivers side fuse box top green connector, right hand side.
Date Posted: May 09, 2005 at 1:35 PM
 I did try the ECM/PCM, but when I hooked my tester to it I never got voltages that varied very much if at all when I reved the engine.  I have not tried looking at the drivers side fuse box. I will be trying that tonight!  Thanks for the quick reply!
-Elementowner6
