2005 Chevrolet Avalanche Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55442
Printed Date: May 06, 2024 at 9:29 PM
Topic: 2005 Chevrolet Avalanche Alarm/Remote Start Wiring
Posted By: 1rstClassSC
Subject: 2005 Chevrolet Avalanche Alarm/Remote Start Wiring
Date Posted: May 09, 2005 at 7:17 PM
Can someone please post the alarm and remote start  wireing diagram for a 2005 Avalanch?
Thanks in advance.
Luis
Posted By: thepencil
Date Posted: May 09, 2005 at 8:10 PM
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / AVALANCHE / 2005 / Remote Start
12volts red (40A), red (40A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition white   +   ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ignition harness
Power Lock use 457G or 456G module
Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601.
Power Unlock see power lock
Lock Motor gray   5wi driver door module in door
Unlock Motor tan   5wi driver door module in door
Parking Lights+ brown   +   driver kick panel
Parking Lights- gray/black   -   switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white   -   hazard switch
Turn Signal(L) dk. green   +   turn signal switch
Turn Signal(R) lt. green   +   turn signal switch
Reverse Light lt. green   +   BCM, black plug, pin F
Door Trigger see notes   -   see notes
Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2, they are in the purple plug at the BCM. Use all four wires and diode isolate each.
Dome Supervision gray/black   +   BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green   -   driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white   ac   instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or fuel injectors and use the wire that is NOT pink, black, or brown.
Wait to start N/A
Brake Wire white   +   brake pedal switch
Parking Brake lt. blue   -   switch or BCM, lt. blu plug, pin A7
Horn Trigger BLACK / YELLOW to black   -   switch or BCM, gray plug, pin B9
Memory Seat 1 red   +   driver door module in door
Memory Seat 2 pink   +   driver door module in door
Memory Seat 3 N/A   +
Interface Module: Category:
Required:
Yes Type:
Passlock 2
Part #: 457G, 555L, or 555T
Notes: The Passlock 2 wire colors are yellow, black, and RED / white (not used).
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: R1racer22
Date Posted: July 23, 2005 at 7:54 PM
is this the same for a 2004 avalanche?
Posted By: Velocity Motors
Date Posted: July 23, 2005 at 8:33 PM
Yes it is the same.
