im looking for the wiring diagram for the power windows i need to identify the prongs on the back of the back of the button assembly
camaro
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / FULL SIZE PICKUP / 2002 / Accessory
12volts red + ignition harness
Ignition pink + ignition harness
Parking Lights+ brown + lt. blue plug at BCM
Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.
Parking Lights- white - lt. blue plug at BCM
Headlight white + lt. blue plug at BCM
Trunk/Hatch Release
Power Sliding Door
Speed Sense dk.GREEN / WHITE ECM
Notes: ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the VSS wire is at pin 3 in the connector labeled black. On the 4.8L, 5.3L, and 6.0L, the VSS wire is located in pin 50 of the red connector.
Wipers
LF Window up/dn blue - brown A driver door switch
RF Window up/dn blue - brown A passenger door switch
LR Window up/dn
RR Window up/dn
Sun Roof open/close
Sun Roof Limit/close
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 555LW
Alternate Part1 #: 555T
Notes:
Door Lock Interface Required:
No Type:
N/A
Part #: N/A
Notes:
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes: Can use the 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Be careful whose advice you buy, but be patient with those who supply it.
