2004 Nissan Pathfinder Alarm/Stereo Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57793
Printed Date: April 28, 2024 at 5:05 PM
Topic: 2004 Nissan Pathfinder Alarm/Stereo Wiring
Posted By: kvlac
Subject: 2004 Nissan Pathfinder Alarm/Stereo Wiring
Date Posted: June 15, 2005 at 11:12 PM
Need wiring diagrams for the alarm,keyless entry etc... to install car starter.  Also need wiring diagram for Satellite radio stock OEM headunit and Satellite radio components for OEM Sirius Satellite radio kit....
Any help out there?  Please
thanks
Charlie
Posted By: thepencil
Date Posted: June 17, 2005 at 10:22 AM
DIRECTWIRE™ WIRING INFORMATION - NISSAN / PATHFINDER / 2004 / Audio
Radio 12v blue / YELLOW or RED / green   +   radio harness
Radio Ground (chassis)
Radio Ignition GREEN / WHITE   +   radio harness
Radio Illumination pink/green   +   radio harness
Factory Amp Turn-on lt. GREEN/ red   +   radio harness or rear amp
Notes: Vehicles with the BOSE system, the front speakers are individually amplified at the speaker and the rear speaker amplifier is in the left rear quarter panel.
Power Antenna red   +   radio harness
LF Speaker +/- green - red   +,- radio harness
RF Speaker +/- brown - BLACK/ white   +,- radio harness
LR Speaker +/- lt. green - BLACK / YELLOW   +,- radio harness
RR Speaker +/- orange - BLACK/ pink   +,- radio harness
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes:
DIRECTWIRE™ WIRING INFORMATION - NISSAN / PATHFINDER / 2004 / Remote Start
12volts WHITE/ green (40A)   +   ignition harness
Starter BLACK / YELLOW   +   ignition harness
Second Starter RED / black   +   ignition harness
Ignition BLACK/ white   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory RED / yellow   +   ignition harness
Second Accessory WHITE/ blue   +   ignition harness
Keysense WHITE/ red   +   ignition harness or SECU, pin 25
Power Lock yellow   -   SECU next to fuse box, pin 11
Notes: The power lock/unlock wires will meter while turning the key in the rear hatch key cylinder.
Power Unlock lt. green (double pulse)   -   SECU next to fuse box, pin 10
Lock Motor blue   5wi SECU next to fuse box, pin 54
Unlock Motor WHITE/ purple   5wi SECU next to fuse box, pin 55
Parking Lights+ pink/black   +   driver kick, harness to rear
Parking Lights- green   -   SECU next to fuse box, pin 20
Hazards same as turn signal wires
Turn Signal(L) gray/blue   +   SECU next to fuse box, pin 47
Turn Signal(R) gray/red   +   SECU next to fuse box, pin 48
Reverse Light yellow   +   driver kick, harness to rear
Door Trigger RED / blue   -   SECU next to fuse box, pin 3
Dome Supervision RED / black   -   SECU next to fuse box, pin 31
Trunk/Hatch Pin blue/white   -   SECU next to fuse box, pin 13
Notes: This wire is for the glass hatch pin. The hatch door pin is common with the door trigger.
Hood Pin yellow/black   -   SECU next to fuse box, pin 6
Trunk/Hatch Release WHITE/ green   -   driver kick, harness to rear
Notes: The fuel door release is pink/black in the same location.
Both of these wires are high current negative, so MUST use relays.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer WHITE/ green or WHITE/ black   ac   TCM, pin 39
Notes: The TCM (Transmission Control Module) is to the left of the brake pedal.
For tach, can also go to any ignition coil or fuel injector and use the wire that is NOT red or black.
Wait to start N/A
Brake Wire GREEN/ YELLOW   +   brake pedal switch
Parking Brake BROWN / white   -   parking brake switch or driver kick
Horn Trigger yellow to lt. GREEN/ black   -   steering column or SECU, pin 42
Memory Seat 1 RED / white   -   Seat Control Unit under seat, pin 22
Memory Seat 2 blue / YELLOW   -   Seat Control Unit under seat, pin 35
Memory Seat 3 N/A   -
Yes Type:
Transponder
Part #: 556UW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.posted_image
