1989-1991 mercury Cougar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5887
Printed Date: October 31, 2024 at 5:49 PM
Topic: 1989-1991 mercury Cougar
Posted By: pepper453
Subject: 1989-1991 mercury Cougar
Date Posted: November 25, 2002 at 7:29 PM
Make:
 Model:
 Year:
Mercury
 Cougar
 1989-1991
Remote Starter  Wiring Colors and Notes
Function
   DTI Color
 Vehicle  Color
 Location
   Notes:
Start:
   Yellow
 RED / LIGHT BLUE
 IGNITION SWITCH HARNESS
   * 1989-90 Tach Wire Is D GREEN/ YELLOW, 1991 Tach Wire Is RED / L BLUE (5.0L DK. GREEN/ YELLOW) Located On All At Engine Contol Module In Passenger Kick Panel. ** See Note #211 - Ford Ignition Switch Connection Diagram.
Ignition  #1:
   Blue
 RED / LIGHT GREEN
Ignition  #2:
   Green
 GRAY / YELLOW (14AWG)
 IGNITION SWITCH HARNESS **
Ignition  #3:
   Wht/Blk
 GRAY / YELLOW-2WIRES
Accessory:
   White
 BLACK/ LIGHT GREEN
Brake  Light:
   Orange
 LIGHT GREEN
 (+) AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
   Green
 DK GREEN/ YELLOW
 AT COIL OR ENGINE CONTROL MODULE *
Parking Lights:
   Yellow
 BROWN
 (+) AT LIGHT SWITCH OR FUSE BOX
Headlights:
   Yellow
 RED / YELLOW
 (+) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
   Brn/Wht
 DARK GREEN/ PURPLE
 (-) IN EITHER KICK PANEL
Diesel  Glow Plug:
   RED / Black
 N/A
Clutch  Bypass Wire:
   n/a
Alarm and Keyless  Entry Wiring Colors and Notes
Function
   DTI Color
 Vehicle  Color
 Location
   Notes:
Constant  +12 Volts:
   Red
 BLACK/ ORANGE AND
 BLACK/ ORANGE-IGNITION SWITCH HARNESS
   *** Without OEM Keyless Entry See Note #203 - Reverse Polarity Door Lock Diagram, With OEM Keyless See Note #202 - Positive Pulse Door Lock Diagram.
Starter  Kill:
   Vlt or Wht
 RED / LIGHT BLUE
Ignition  +12 Volts:
   Orange
 RED / LIGHT GREEN
Dome  Lights/Superv:
   Brown
 BLACK/ LIGHT BLUE
 (+) AT PIN SWITCH
OEM Horn:
   Blue
 YELLOW/LIGHT GREEN
 (-) STEERING COLUMN HARNESS
Power  Lock:
   Wht/Red
 PINK / YELLOW
 DRIVER'S KICK PANEL ***
Power  Unlock:
   Yel/Red
 PINK/LIGHT GREEN
Trunk  Release:
   Grn/Wht
 PURPLE / YELLOW
 (+) AT RELEASE SWITCH
Alarm  Input Wire:
   R/W or Gy/Bk
 BLACK/ LIGHT BLUE
 (+) AT PIN SWITCH
Posted By: John Doe
Date Posted: November 26, 2002 at 10:58 AM
Do you need help with anything or am I missing something?
