2005 Nissan Maxima Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59395
Printed Date: May 07, 2024 at 6:19 PM
Topic: 2005 Nissan Maxima Alarm/Remote Start Wiring
Posted By: ratmkicksass
Subject: 2005 Nissan Maxima Alarm/Remote Start Wiring
Date Posted: July 13, 2005 at 10:48 PM
i am trying to install a remote starter on a 2005 nissan maxima, but need the wiring diagram. If anybody out there has it, please post
Posted By: chungo
Date Posted: July 13, 2005 at 11:35 PM
DIRECTWIRE™ WIRING INFORMATION - NISSAN / MAXIMA / 2005 / Remote Start[PRINT THIS PAGE]
12volts | green (40A) | + | ignition harness | Starter | BLACK/ red | + | ignition harness | Second Starter | BLACK / YELLOW | + | ignition harness | Ignition | BLACK/ red | + | ignition harness | Second Ignition | N/A | | | Third Ignition | N/A | | | Accessory | red | + | ignition harness | Second Accessory | WHITE/ blue | + | ignition harness | Keysense | BLACK/ red | + | ignition harness or BCM, pin 37 | Notes: The BCM (Body Control Module) is between the steering column and the fuse box. | Power Lock | blue or pink/blue | - | driver door module in door | Notes: Meter this wire while turning the key in the driver door key cylinder. | Power Unlock | red (double pulse) | - | driver door module in door | Notes: Meter this wire while turning the key in the driver door key cylinder. | Lock Motor | gray | 5wi | BCM, pin 50 | Notes: The BCM (Body Control Module) is between the steering column and the fuse box. | Unlock Motor | green | 5wi | BCM, pin 44 | Notes: The BCM (Body Control Module) is between the steering column and the fuse box. | Parking Lights+ | RED / blue | + | driver kick, harness to rear | Parking Lights- | N/A | | | Hazards | GREEN/ red | - | BCM, pin 29 | Notes: The BCM (Body Control Module) is between the steering column and the fuse box. | Turn Signal(L) | GREEN/ black | + | BCM, pin 45 | Notes: The BCM (Body Control Module) is between the steering column and the fuse box. | Turn Signal(R) | GREEN/ YELLOW | + | BCM, pin 46 | Notes: The BCM (Body Control Module) is between the steering column and the fuse box. | Reverse Light | GREEN / WHITE | + | driver kick, harness to rear | Door Trigger | see notes | - | BCM | Notes: The LF door is lt. blue in pin 62, the RF door is BROWN / white in pin 12, the LR door is RED / black in pin 63, and the RR door is blue/red in pin 13. Use all four wires and diode isolate each.
The BCM (Body Control Module) is between the steering column and the fuse box. | Dome Supervision | red | - | BCM, pin 48 | Notes: The BCM (Body Control Module) is between the steering column and the fuse box. | Trunk/Hatch Pin | PURPLE / white | - | BCM, pin 57 | Notes: The BCM (Body Control Module) is between the steering column and the fuse box. | Hood Pin | N/A | | | Trunk/Hatch Release | blue or blue/white | - | BCM, pin 30 | Notes: The BCM (Body Control Module) is between the steering column and the fuse box.
The fuel door release is green in the driver kick, in the harness to the rear. It is a high current negative wire. | Power Sliding Door | N/A | | | Factory Alarm Arm | arms with lock | | | Factory Alarm Disarm | disarms with unlock | | | Disarm No Unlock | single pulse power unlock wire | | | Tachometer | NOT red or black | ac | any ignition coil or fuel injector | Wait to start | N/A | | | Brake Wire | RED / green | + | brake pedal switch | Parking Brake | pink/black | - | parking brake switch | Horn Trigger | GREEN / WHITE | - | horn switch | Memory Seat 1 | blue/white | - | ADP Control Unit, pin 9 | Notes: The ADP (Automatic Drive Positioner) control unit is the second module below the display in the dash.
| Memory Seat 2 | purple | - | ADP Control Unit, pin 25 | Notes: The ADP (Automatic Drive Positioner) control unit is the second module below the display in the dash.
| Memory Seat 3 | N/A | - | | Interface Module: | Category: Immobilizer Bypass | Required: Yes | Type: Transponder | Part #: 556UW | Alternate Part1 #: 555U | Notes: Standard on all models. |
