remote start, 2000 Dodge Dakota
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60042
Printed Date: May 15, 2024 at 7:10 PM
Topic: remote start, 2000 Dodge Dakota
Posted By: cman911
Subject: remote start, 2000 Dodge Dakota
Date Posted: July 24, 2005 at 4:42 PM
I have a 2000 dodge dakota with a aolin alarm on it when i bought it.  I have the same problem as others with the dome light staying on for 30 sec.  also the remote start will not start it just beeps 3 times.  i brought it to an install shop and they could not figure it out.  any thing special on a 2000, at, power everything. i was told something about a GREEN/ red wire.  what is it and how to hook it up or tell the shop.  thanks for any advice on this matte would help.
Posted By: mo12v
Date Posted: July 24, 2005 at 7:49 PM
Does your Alarm trigger after arming?
You might check your Brake wire connection, Hood Pin, Neutral Safety, etc. for your Remote Start issue.  If the RS senses a ground from Hood Pin or Brake Light wire is not supplying ground then it would not work.
As far as GREEN/ Red wire:
Ignition #3GREEN/ RED (18 GA)IGNITION SWITCH HARNESS **
** Not Powering Up Results In Check Engine Light
BLACK/ WHITE Wire Must Be Powered During Remote Start To Keep The Check Engine Light Off.
MO
Posted By: cman911
Date Posted: July 25, 2005 at 1:42 PM
any body have any experience on wiring up an alarm/remote start combo system on a 2000 Dodge dakota with power everything and automatic tranny.  I had one installed and they could not figure out why the remote start would not engage.  I have been told of a GREEN/ red of like a 16 or 18 gauge wire only on the 2000 models any info would be greatly appreciated.
Posted By: cman911
Date Posted: July 25, 2005 at 1:43 PM
oh yeah also any body got the wiring diagram of the factory alarm on one of these trucks i need to get tha pesky dome light delay off.
Posted By: Velocity Motors
Date Posted: July 25, 2005 at 8:15 PM
When you say that it would not start, does that mean that it doesn't crank over or it does crank over, but doesn't stay running ? If you have OEM alarm as well, then you need to add relays to bypass the system. These trucks are very easy to do, I did one today and all wires are located in the ignition harness for the remote start wires ( no Immobilizer system ) and the keyless is a little different where you have to use (+) for the lock and 5 wire the unlock. Aside from this, there's nothing special about the truck.
Posted By: thepencil
Date Posted: July 26, 2005 at 12:33 PM
DIRECTWIRE™ WIRING INFORMATION - DODGE / DAKOTA PICKUP / 2000 / Remote Start
12volts red or pink/black    +   ignition harness
Starter blue / YELLOW    +   ignition harness
Second Starter
Ignition dark blue    +   ignition harness
Second Ignition BLACK/ orange    +   ignition harness
Third Ignition GREEN/ red    +   ignition harness
Accessory BLACK/ white    +   ignition harness
Second Accessory
Keysense
Power Lock org/pur or grn/blk    +   drivers kick panel
Power Unlock pink/purple    +   drivers kick panel
Notes: Vehicles with keyless entry, have to 5 wire the unlock wire.
Lock Motor
Unlock Motor
Parking Lights+ BLACK / YELLOW      behind fuse box
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow    -   behind fuse box
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm lt. GREEN/ orange   -   drivers door harness
Notes: Must use relays and set up for (-) negative trigger. Place a 600 ohm resistor to the lt. GREEN/ orange for arm, and a 1300 ohm resistor on the same wire for disarm. This wire will also lock the doors, and it will unlock with a double pulse.
Factory Alarm Disarm same wire
Disarm No Unlock
Tachometer blk/gry or gry/blk      coil pass. sid of eng.
Wait to start
Brake Wire WHITE/ tan    +   at brake switch
Parking Brake
Horn Trigger BLACK/ red    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: cman911
Date Posted: July 29, 2005 at 4:13 PM
okay my truck is a 2000 dodge dakota with auto trans and power everything.  its got this remote start/alarm combo on it.  some brand i have never heard of (Aolin?).  anyways the remote start dont work it powers up the accessories and all just no cranking of the engine. I was told of a GREEN/ red wire in the harness that is about 16 to 18 gauge that is only on this year dodge.  well the only green red wire i see is not hooked up to anything.  could that be the problem and if so anyone know how it is to be hooked up?  just so i coulod tell an install shop.  any help would be greatfully appreciated.  thanks guys.
Date Posted: August 02, 2005 at 2:39 PM
Any chance you might got an immobolizer in the vehicle?
Date Posted: August 02, 2005 at 3:05 PM
Make sure that the starter wire off the remote start is attached to the motor side of the starter disable relay otherwise you will get a no crank problem like you have now.
Posted By: cman911
Date Posted: August 02, 2005 at 7:42 PM
i dont think i have an immobilzer on the truck.  I would have figured one of the two shops i went to would have thought about that.  Course i could be wrong.  thanks for all your replys i appreciate it very much i will investigate further.
