97 Acura 1.6 el
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60527
Printed Date: May 18, 2024 at 4:35 AM
Topic: 97 Acura 1.6 el
Posted By: cerwinvega19
Subject: 97 Acura 1.6 el
Date Posted: August 02, 2005 at 9:40 AM
Hey anybody got a 97 Acura 1.6 el wiring diagram? Thanks.
Posted By: thepencil
Date Posted: August 02, 2005 at 9:43 AM
I may have one for you if you could tell me what you are trying to accomplish. What type of wiring diagram are you looking for?
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: August 02, 2005 at 11:47 AM
Oh, sorry, i need alarm and remote starter info. it's a 97 or a 98 cant remember, but one of the two.
Posted By: Odyssey03
Date Posted: August 02, 2005 at 11:59 AM
If you can wait for a few hours...I have all the information...Just installed a R/S plus alarm on my 98 1.6 EL (manual transmission) by myself...Need to go home during lunch hour to get them...
Date Posted: August 02, 2005 at 12:10 PM
DIRECTWIRE™ WIRING INFORMATION - ACURA / INTEGRA / 1997 / Remote Start
[PRINT THIS PAGE]
12volts white    +   ignition harness
Starter BLACK/ white    +   ignition harness
Second Starter
Ignition BLACK / YELLOW    +   ignition harness
Second Ignition
Third Ignition
Accessory yellow    +   ignition harness
Second Accessory
Keysense
Power Lock BLACK/ white    -   drivers kick panel
Notes: In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch.
Power Unlock BLACK/ red    -   drivers kick panel
Lock Motor
Unlock Motor
Parking Lights+ RED / black      grn plug above fusebox
Notes: Also a male blade terminal is available in fuse box.
Parking Lights- GREEN/ YELLOW      factory alarm (if equipped)
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. GREEN/ red    -   drivers kick panel
Looks like 14 awg wire but mostly insulation.
Dome Supervision use door trigger
Trunk/Hatch Pin green    -
Notes: 12 pin blue plug on top center of fusebox.
Hood Pin yellow/red    -   drivers kick panel
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock
Tachometer blue   AC   distributor
Notes: Also found in a 16 pin white or gray plug to the left of the fusebox.
Wait to start
Brake Wire GREEN / WHITE    +   brake switch
Parking Brake
Horn Trigger gray or blu/grn    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
DIRECTWIRE™ WIRING INFORMATION - ACURA / INTEGRA / 1998 / Remote Start
[PRINT THIS PAGE]
Second Starter
Second Ignition
Third Ignition
Second Accessory
Keysense
Lock Motor
Unlock Motor
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Trunk/Hatch Release blue    -   at switch
Notes: Trunk release only works with the doors unlocked.
Power Sliding Door
Disarm No Unlock
Wait to start
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
No Type:
N/A
Part #: N/A
Notes:
Date Posted: August 02, 2005 at 2:14 PM
Here is the wiring information for your 97 EL:
12V Constant Power: White(+), Ignition Switch Harness
Starter: BLACK/ White(+), Ignition
Ignition 1: BLACK / YELLOW(+), Ignition
Accessory 1: Yellow(+), Ignition
Accessory 2: WHITE/ Black(+), Ignition
Parking Light: RED / Green(+), Fuse box
Power Lock: GREEN / WHITE(-), Driver Kick Panel
Power Unlock: GREEN/ Orange(-), Driver Kickl
Door Pin: Light Green(-), Fuse
Doomlight Supervision: Light GREEN/ Black(-), Driver Kick
Trunk Release: Blue/Red(+), Keyless Entry Module under Driver's Seat
Horn: Gray(-), Steering Column Harness
Tach: Blue(AC), Two-Pin Plug under Hood at Driver Dide
Brake: GREEN / WHITE(+), Switch above Brake Pedal
Factory Alarm Disarm: Blue w/Silver Dots, Driver Kick
E-Brake: RED / Green (+), Daytime Light Control Module on Driver Side
Good luck.
Date Posted: August 02, 2005 at 2:40 PM
Thanks!
