2005 Chrysler Pacifica Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60530
Printed Date: May 05, 2024 at 12:49 AM
Topic: 2005 Chrysler Pacifica Alarm/Remote Start Wiring
Posted By: colouny
Subject: 2005 Chrysler Pacifica Alarm/Remote Start Wiring
Date Posted: August 02, 2005 at 10:23 AM
I want to install Car Alarm system, And need some ino about wire colours and location, maybe someone could help me with this. Than you all in advance
Car Audio and car security systems installer. Best in Car audio.
Posted By: thepencil
Date Posted: August 02, 2005 at 10:38 AM
DIRECTWIRE™ WIRING INFORMATION - CHRYSLER / PACIFICA / 2005 / Security
12volts lt. blue/red (10A)   +   ignition harness
Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12V.
Starter yellow   +   ignition harness
Ignition pink/gray   +   ignition harness
Power Lock PURPLE / lt. blue   -   driver door module in door
Notes: Lock is negative trigger thru a 1.8K ohm resistor. Unlock is negative trigger thru a 750 ohm resistor. Unlock requires a double pulse. MUST use relays.
This wire is not present on the base models which do not have central lock thru the key cylinder on the door. However, a wire can be added to the pin location where the wire would normally be found. It is pin 13, in the 20 pin plug at the driver door module in the door. For reference, the wires next to it are org/tan in pin 12, and lt. blu/wht in pin 14.
Power Unlock same as power lock wire
Lock Motor tan/white   5wi driver door module in door
Unlock Motor tan/lt. green   5wi driver door module in door
Disarm Defeat PURPLE / lt. green   5wi passenger kick, door harness
Parking Lights+ use negative wire
Parking Lights- BROWN / white   -   headlight switch or BCM, C5, pin 31
Notes: The parking lights are negative trigger thru a 920 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch.
The BCM (Body Control Module) is on the driver side firewall under the dash.
Hazards WHITE/ dk. blue   -   hazard switch or BCM, C5, pin 1
Notes: The BCM (Body Control Module) is on the driver side firewall under the dash.
Turn Signal(L) use hazards wire
Turn Signal(R) use hazards wire
Door Trigger see notes   -   see notes
Notes: The driver door trigger is purple at the driver door module in the door. The passenger door trigger is PURPLE / white at the passenger door module in the door. The LR door trigger is PURPLE / gray at the BCM, C2, pin 8. The RR door trigger is purple / YELLOW at the BCM, C3, pin 5. Use all four wires and diode isolate each.
Dome Supervision yellow/white   -   driver A pillar or BCM, C3, pin 8
Trunk/Hatch Pin PURPLE / orange   -   driver kick or BCM, C3, pin 29
Hood Pin N/A
Trunk/Hatch Release PURPLE / tan   -   driver A pillar or BCM, C3, pin 7
Notes: This wire is for the power liftgate. It is negative trigger thru a 4.7K ohm resistor. MUST use relay.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT BROWN / white   ac   any ignition coil or fuel injector
Horn Trigger dk. GREEN/ purple   -   horn switch
Memory Seat 1 PURPLE / brown   -   driver door module in door
Notes: Memory seat 1 is negative trigger thru an 8K ohm resistor. MUST use relay.
Memory Seat 2 same as memory seat 1 wire   -
Notes: Memory seat 2 is negative trigger thru a 2.41K ohm resistor. MUST use relay.
Memory Seat 3 N/A   -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Sentry Key
Part #: 556CW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Notes: Standard on all models.
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: colouny
Date Posted: August 03, 2005 at 12:14 AM
Thanx for your information. It helped me very much.
Posted By: pettinej
Date Posted: October 03, 2005 at 7:14 PM
I just did this car. I have one problem. When I remote start everything is fine. When I use the Key the windows, heater control and radio do not work. If I disconect the ignition wire everything works again. I am using an audiovox APS-596 two way remote start system. The only thing I can think of is that the remote starter is leaving some voltage on the ignition wire or loading it down. If anyone has any advice I would appreciate it.
Posted By: colouny
Date Posted: October 04, 2005 at 12:56 AM
Sorry but in our country we dont install remote start systems, because its not popular.
GOOD Luck
