DIRECTWIRE™ WIRING INFORMATION - VOLVO / S80 / 1999 / Remote Start
12volts RED / black (10A) + ignition harness
Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12v.
Starter yellow/white + ignition harness
Second Starter N/A
Ignition blue/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory purple + ignition harness
Second Accessory N/A
Keysense yellow (required) + ignition harness
Power Lock PURPLE / white - driver door module in door
Notes: These are the driver door key cylinder wires, meter by turning the key in the door.
Power Unlock blue/white (double pulse) - driver door module in door
Lock Motor yellow 5wi driver door module in door
Unlock Motor gray 5wi driver door module in door
Parking Lights+ white + fuse box under driver dash
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger white + underdash light
Dome Supervision comes on with unlock
Trunk/Hatch Pin BROWN / orange - trunk pin switch
Notes: Also found pink at the central electronic module.
Hood Pin yellow - hood pin switch
Trunk/Hatch Release gray/white 5wi white plug behind driver taillight
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock disarms with remote start
Tachometer see notes ac any ignition coil
Notes: Use any of the following; blue, brown, yellow, pink, purple, or gray.
Wait to start
Brake Wire yellow + brake pedal switch
Parking Brake
Horn Trigger yellow - central electronic module
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes:
Be careful whose advice you buy, but be patient with those who supply it.
