2003 Mitsubishi Galant
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61763
Printed Date: May 02, 2024 at 6:09 AM
Topic: 2003 Mitsubishi Galant
Posted By: hf integrale
Subject: 2003 Mitsubishi Galant
Date Posted: August 20, 2005 at 9:50 PM
Would anybody have a wiring diagram for installing remote start?
Posted By: thepencil
Date Posted: August 22, 2005 at 8:32 AM
DIRECTWIRE™ WIRING INFORMATION - MITSUBISHI / GALANT / 2003 / Remote Start
12volts blue / YELLOW   +   ignition harness
Starter BLACK / YELLOW   +   ignition harness
Second Starter N/A
Ignition BLACK/ white   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory blue/red   +   ignition harness
Second Accessory blue/black   +   ignition harness
Keysense blue/red      ignition harness
Notes: This wire rests at ground, and goes to an open circuit when the key is inserted into the ignition cylinder.
Power Lock purple   -   pin 33 at ETACS ECU
Notes: The ETACS ECU is attached to the back of the fuse box.
Power Unlock lt. GREEN/ red   -   pin 34 at ETACS ECU
Lock Motor blue/red   5wi pin 19, 28P plug below fuses
Unlock Motor blue/black   5wi pin 22 at ETACS ECU
Parking Lights+ GREEN/ orange   +   pin 5, 43 pin plug in DKP
Parking Lights- N/A
Hazards GREEN/ YELLOW   -   pin 55 at ETACS ECU
Turn Signal(L) GREEN/ blue   +   pin 22, 28P plug below fuses
Turn Signal(R) GREEN/ YELLOW   +   pin 27, 28P plug below fuses
Reverse Light RED / blue   +   pin 9, 43 pin plug in DKP
Door Trigger     -
Notes: The driver door trigger and rear door trigger are in a 15 pin plug above the fuses. The driver door is lt. green in pin 6, and the rear door is ORANGE / black in pin 10. The passenger door trigger is lt. green in pin 65 at the ETACS ECU. Use all three wires and diode isolate each.
Dome Supervision GREEN/ orange   -   pin 1,3 pin plug above fuses
Trunk/Hatch Pin white   -   pin 37 at ETACS ECU
Hood Pin blue/black   -   pin 24 at ETACS ECU
Trunk/Hatch Release GREEN / WHITE   5wi pin 32 at ETACS ECU
Power Sliding Door N/A
Factory Alarm Arm lt. GREEN/ black   -   pin 42 at ETACS ECU
Factory Alarm Disarm red   -   pin 25 at ETACS ECU
Disarm No Unlock
Tachometer white   ac   engine speed detect conn
Notes: The engine speed detection connector is a single pin connector in the fuse/relay box under the hood.
Can also go to one of the ignition coils or the distributor assembly and use the BLACK/ blue or WHITE/ green wire.
Wait to start N/A
Brake Wire green   +   brake pedal switch
Parking Brake YELLOW /GREEN   -   parking brake switch
Horn Trigger lt. green   -   pin 44 at ETACS ECU
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Alternate Part3 #: 555U
Notes:
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: August 23, 2005 at 7:57 PM
Thats great, thank You very much, I'm going to install it this weekend just to be safe.You never know when the winter hits here in Canada...lol.
Date Posted: August 24, 2005 at 8:22 AM
You are quite welcome. I know what you mean. Warmer weather is just way too short up here.
