2001 Chevy Silverado 12v Switched Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61925
Printed Date: April 30, 2024 at 5:16 PM
Topic: 2001 Chevy Silverado 12v Switched Wire
Posted By: jackmacokc
Subject: 2001 Chevy Silverado 12v Switched Wire
Date Posted: August 23, 2005 at 8:01 PM
Can someone tell me of one that is 12v switched for me to hardwire my radar detector?
Or a link to someone who has done it? I can't find anything on google.
Thanks!
Posted By: endless talent
Date Posted: August 24, 2005 at 12:47 AM
Pink is Ignition
Posted By: thepencil
Date Posted: August 24, 2005 at 9:45 AM
For safety make sure you add a fuse between the pink wire and the wire connecting to your radar detector.
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / SILVERADO / 2001 / Accessory
12volts red   +   ignition harness
Ignition pink   +   ignition harness
Parking Lights+ brown   +   lt. blue plug at BCM
Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.
Parking Lights- white   -   lt. blue plug at BCM
Headlight white   +   lt. blue plug at BCM
Trunk/Hatch Release
Power Sliding Door
Speed Sense dk. GREEN / WHITE      ECM
Notes: ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the VSS wire is at pin 3 in the connector labeled black. On the 4.8L, 5.3L, and 6.0L, the VSS wire is located in pin 50 of the red connector.
Wipers
LF Window up/dn blue - brown   A   driver door switch
RF Window up/dn blue - brown   A   passenger door switch
LR Window up/dn
RR Window up/dn
Sun Roof open/close
Sun Roof Limit/close
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: 555T
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes:
Door Lock Interface Required:
No Type:
N/A
Part #: N/A
Notes:
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes: Can use the 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
