DIRECTWIRE™ WIRING INFORMATION - NISSAN / TITAN / 2005 / Security
12volts green (40A) + ignition harness
Starter brown + ignition harness
Ignition BLACK/ red + ignition harness
Power Lock blue - driver door module in door
Power Unlock red (double pulse) - driver door module in door
Lock Motor purple 5wi BCM to right of column, pin 65
Unlock Motor green 5wi BCM to right of column, pin 59
Disarm Defeat GREEN/ YELLOW 5wi BCM to right of column, pin 66
Parking Lights+ RED / blue + dimmer switch on dash
Parking Lights- N/A
Hazards WHITE/ black - BCM to right of column, pin 29
Turn Signal(L) GREEN/ black + BCM to right of column, pin 60
Turn Signal(R) GREEN/ YELLOW + BCM to right of column, pin 61
Door Trigger see notes - BCM to right of column
Notes: The LF door trigger is lt. blue in pin 47. The RF door trigger is RED / blue in pin 12. The LR door trigger is RED / yellow in pin 48. The RR door trigger is RED / white or gray in pin 13. Use all four wires and diode isolate each.
Dome Supervision blue - BCM to right of column, pin 63
Notes: The blue wire is for the dome lights and puddle lights. For the step lights use RED / white in pin 62 at the BCM.
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT WHITE/ blue or black ac any ignition coil
Horn Trigger RED / white - horn switch
Memory Seat 1 lt. GREEN/ black - memory mod. left of column, pin 9
Memory Seat 2 pink/blue - memory mod. left of column, pin 25
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on the SE and LE models. Optional on the Crew Cab XE models.
Be careful whose advice you buy, but be patient with those who supply it.
DIRECTWIRE™ WIRING INFORMATION - NISSAN / TITAN / 2005 / Audio
Radio 12v yellow + radio harness
Radio Ground (chassis)
Radio Ignition purple + radio harness
Radio Illumination RED / blue + radio harness
Factory Amp Turn-on GREEN / WHITE + radio harness or amplifier
Notes: If equipped, the BOSE amplifier is to the right of the steering column, behind the BCM.
Power Antenna N/A
LF Speaker +/- blue/white - blue/red +,- radio harness or amplifier
RF Speaker +/- WHITE/ black - blue/black +,- radio harness or amplifier
LR Speaker +/- lt. blue - BLACK / YELLOW +,- radio harness or amplifier
RR Speaker +/- ORANGE / blue - RED / blue +,- radio harness or amplifier
Yes Type:
Transponder
Part #: 556UW
