2000 Acura TL, VSS Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62758
Printed Date: April 29, 2024 at 9:45 AM
Topic: 2000 Acura TL, VSS Wire
Posted By: locon69
Subject: 2000 Acura TL, VSS Wire
Date Posted: September 16, 2005 at 2:21 PM
can someone please tell me the vss wire color  for a 2000 acura tl
streetflow
Posted By: thepencil
Date Posted: September 22, 2005 at 11:27 AM
DIRECTWIRE™ WIRING INFORMATION - ACURA / TL / 2000 / Accessory
12volts white   +   ignition harness
Ignition BLACK / YELLOW   +   ignition harness
Parking Lights+ RED / black   +   4 pin grn plug top of pass. fuse box
Parking Lights- RED / yellow   -   headlight switch
Headlight blue/red   -   headlight switch
Trunk/Hatch Release WHITE/ red   +   passenger MUX module
Notes: The passenger MUX module is located behind the glove box.
Power Sliding Door N/A
Speed Sense blue/white      cruise control unit
Notes: The cruise control unit is above the accelerator pedal.
Wipers blue (L), blue / YELLOW (H)   -   steering column
LF Window up/dn RED / yellow - RED / blue   A   LF window switch in door
RF Window up/dn blue/white - blue / YELLOW   A   RF window switch in door
LR Window up/dn RED / blue - RED / yellow   A   LR window switch in door
RR Window up/dn RED / blue - RED / yellow   A   RR window switch in door
Sun Roof open/close GREEN/ YELLOW - GREEN/ red   A   relays left of driver fuse box
Sun Roof Limit/close N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: 555H
Alternate Part3 #: 555U
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes:
Be careful whose advice you buy, but be patient with those who supply it.posted_image
