Print Page | Close Window |
2005 Saturn Ion Remote Starter/AlarmPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63301 Printed Date: May 02, 2024 at 12:09 PM Topic: 2005 Saturn Ion Remote Starter/Alarm Posted By: lyonsjustin Subject: 2005 Saturn Ion Remote Starter/Alarm Date Posted: September 26, 2005 at 12:20 PM Trying to install a remote starter and alarm but can't find any 05 wiring diagrams??? Help. I"m installing CarVox model King-Eagle. It's a two-way LCD vehical security system with remote start. Any suggestions?
Replies: Posted By: thepencil Date Posted: September 29, 2005 at 12:25 PM DIRECTWIRE™ WIRING INFORMATION - SATURN / ION / 2005 / Remote Start 12volts red (40A), red (30A) + pins 37 and 34, BCM C1 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Starter yellow (not for remote start) - pin 48 or 46, blue plug, ECM Notes: The ECM (Engine Control Module) is on the driver side of engine compartment, near coolant over flow container. There is a white wire and a WHITE/ black wire at the ignition harness that performs the following: key sense, second ignition, starter, and Passlock resistance. Refer to DirectFax document 1610 for remote start interface information. Second Starter N/A Ignition dk. blue + ign harn or pin 7, BCM C4 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Second Ignition see starter wire notes Third Ignition N/A Accessory brown + ign harn or pin 6, BCM C4 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Second Accessory N/A Keysense see starter wire notes Power Lock white - pin 33, BCM C3 Notes: Lock is a straight negative trigger. Unlock is negative trigger thru a 1.5K ohm resistor. MUST use relays. The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Power Unlock same as power lock wire Lock Motor gray 5wi pin 51, BCM C3 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Unlock Motor tan 5wi pin 2, BCM C3 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Parking Lights+ brown + switch or pin 2, BCM C4 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Parking Lights- N/A Hazards lt. blue - switch or pin 40, BCM C4 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Turn Signal(L) lt. blue (F), yellow (R) + pins 44 and 43, BCM C3 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Turn Signal(R) dk. blue (F), dk. green (R) + pins 46 and 45, BCM C3 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Reverse Light lt. green + harness under driver seat Door Trigger lt. grn/blk (D), lt. blue (P) - pins 45 and 44, BCM C4 Notes: Use both wires and diode isolate each. The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Dome Supervision white - pin 11, BCM C3 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Trunk/Hatch Pin ORANGE / black - light in trunk Notes: On models with keyless entry it is also dk. green, pin 35, in the BCM C3. Hood Pin N/A Trunk/Hatch Release BLACK/ white + switch or pin 1, BCM C3 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Power Sliding Door N/A Factory Alarm Arm factory remote only Factory Alarm Disarm factory remote only Disarm No Unlock with ignition and Passlock Tachometer NOT pink or pink/black ac any fuel injector Wait to start N/A Brake Wire lt. blue + switch or pin 8, BCM C2 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Parking Brake lt. blue - switch or pin 43, BCM C4 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Horn Trigger black - switch or pin 33, BCM C4 Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug. Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Interface Module: Category: Immobilizer Bypass Required: Yes Type: Passlock Part #: 556LW Alternate Part1 #: 555LW Notes: Refer to DirectFax document 1610 for remote start interface information. Interface Module: Category: Door Lock Interface Required: Yes Type: Multiplex Part #: 456LW Notes: This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter. Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. ------------- Be careful whose advice you buy, but be patient with those who supply it. Posted By: dougie109 Date Posted: October 13, 2005 at 6:09 PM i have the exact same unit.. the shop couldn't even install the auto start.. kept trying to start while it was already running? yeah i dont get it either but i would suggest getting a compustar... much better regards Douglas Posted By: attlfrank Date Posted: December 13, 2005 at 10:49 AM thanx boomer,sorry it took so long,,I don't have my own computer
Posted By: dea,can Date Posted: January 12, 2006 at 1:55 AM www.autostart.ca then go to downloads ,go to wiring info type this number in 533865167464 it will give pics .
------------- dragon |
