Print Page | Close Window |
2005 Chevy CobaltPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63314 Printed Date: May 06, 2024 at 10:52 PM Topic: 2005 Chevy Cobalt Posted By: jshgrad1 Subject: 2005 Chevy Cobalt Date Posted: September 26, 2005 at 4:17 PM I used to install full time back in the day and I want to put an alarm/remote start combo (dei) into my new 05 Cobalt LS. If anyone has the color code for tach and etc door locks.. It would be Great! Thank You, Josh
Replies: Posted By: thepencil Date Posted: September 29, 2005 at 12:19 PM DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / COBALT / 2005 / Remote Start 12volts RED / black (50A) + BCM, C3, pin D1 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Starter yellow (not for remote start) - PCM, blue plug, pin 48 or 46 Notes: The PCM (Powertrain Control Module) is on the driver side fender, in front of the underhood fuse block. There is a white wire and a WHITE/ black wire at the ignition harness that performs the following: key sense, second ignition, starter, and Passlock resistance. Refer to DirectFax document 1610 for remote start interface information. Second Starter N/A Ignition yellow + ign harn or BCM, C4, pin D3 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Second Ignition see starter wire notes Third Ignition N/A Accessory brown + ign harn or BCM, C4, pin C8 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Second Accessory N/A Keysense see starter wire notes Power Lock white - driver kick or BCM, C1, pin 7 Notes: Lock is a straight negative trigger. Unlock is negative trigger thru a 1500 ohm resistor. MUST use relays. The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Power Unlock same as power lock wire Lock Motor gray 5wi driver kick or BCM, C3, pin A4 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Unlock Motor tan 5wi driver kick or BCM, C3, pin B1 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Parking Lights+ brown + driver kick or BCM, C3, pin A7 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Parking Lights- BROWN / white - switch or BCM, C2, pin 5 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Hazards white - switch or BCM, C2, pin 9 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Turn Signal(L) lt. blue (F), yellow (R) + BCM, C1, pin 35 and C3, pin A9 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Turn Signal(R) dk. blue (F), dk. green (R) + BCM, C1, pin 17 and C3, pin A12 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Reverse Light lt. green + driver kick, harness to rear Door Trigger gray/black (D), tan/white (P) - each kick or BCM, C1, pins 22 and 19 Notes: Use both wires and diode isolate each. The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Dome Supervision gray - BCM, C3, pin A10 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Trunk/Hatch Pin ORANGE / black - BCM, C1, pin 55 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Hood Pin N/A Trunk/Hatch Release tan - switch or BCM, C2, pin 10 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Power Sliding Door N/A Factory Alarm Arm factory remote only Factory Alarm Disarm factory remote only Disarm No Unlock with ignition and Passlock Tachometer NOT pink or pink/black ac any fuel injector Wait to start N/A Brake Wire lt. blue + switch or BCM, C2, pin 54 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Parking Brake lt. blue - switch or BCM, C1, pin 14 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Horn Trigger tan - switch or BCM, C2, pin 14 Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Interface Module: Category: Immobilizer Bypass Required: Yes Type: Passlock Part #: 556LW Alternate Part1 #: 555LW Notes: Refer to DirectFax document 1610 for remote start interface information. Standard on all models. This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter. Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. ------------- Be careful whose advice you buy, but be patient with those who supply it. |
