2002 Jaguar X-Type, S-Type Alarm/Stereo Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6336
Printed Date: May 03, 2024 at 9:27 AM
Topic: 2002 Jaguar X-Type, S-Type Alarm/Stereo Wiring
Posted By: Patel
Subject: 2002 Jaguar X-Type, S-Type Alarm/Stereo Wiring
Date Posted: December 06, 2002 at 4:37 PM
Just wondering if and when you would have wiring information for a 2002 Jaguar X-Type. Have a customer with such a car and need sum more info. Thanking you in advance for any help.
Posted By: Patel
Date Posted: December 06, 2002 at 4:41 PM
*Also if anyone can give me any advice on anything unexpected. specifically the door locks and transponder
Posted By: Velocity Motors
Date Posted: December 07, 2002 at 12:21 AM
This information is for the S-Type, not sure if you had a typo or not ? | ITEM | WIRE COLOR |POL| WIRE LOCATION | | 12V|RED / grn & RED / org |+ |ignition harness | | STARTER|gry/blk or lt. blue |+ |ignition harness | | IGNITION|GREEN/ black |+ |ignition harness | | SECOND IGNITION|pink/white |+ |ignition harness | | THIRD IGNITION|RED / wht (key sense)|+ |ignition harness | | ACCESSORY|yellow |+ |ignition harness | | SECOND ACCESSORY|pink / YELLOW |+ |ignition harness | | POWER LOCK|BLACK/ blue |- |DDM *1 | | POWER UNLOCK|BLACK/ white *2 |- |DDM *1 | | LOCK MOTOR|yellow/black | |DDM *1 | | UNLOCK MOTOR|WHITE/ purple | |DDM *1 | | DISARM DEFEAT|WHITE/ green | |pass. kick, harness to rear | | PARKING LIGHTS +|use neg. wire only | | | | PARKING LIGHTS -|WHITE/ green *3 | |headlight switch | | HEADLIGHTS|WHITE/ green *3 |*3 |headlight switch | | DOOR TRIGGER|BLACK/ white *4 |- |underdash light | | DOME SUPERVISION|comes on w/unlock | | | | TRUNK/HATCH PIN|WHITE/ black |- |REM *5 | |TRNK/HTCH RELEASE|BLACK/ blue |- |release switch or REM *5 | | FCTRY ALARM ARM|arms w/ lock | | | |FCTRY ALRM DISARM|disarms w/ unlock | | | | TACHOMETER|brown or brn/stripe | |main harness pass. firewall | | SPEED SENSE| | | | | BRAKE WIRE|org/yel or org/blu |+ |brake pedal switch | | HORN TRIGGER|gray/orange |- |FEM *5 | | WIPERS|RED / blk(L),RED / grn(H|+ |wiper motor | | LF WINDOW UP/DN|white - yellow |A |DDM *1 | | RF WINDOW UP/DN|wht/pur - yel/pur |A |FEM *5 | | LR WINDOW UP/DN|blu/red - pur/blu |A |REM *5 | | RR WINDOW UP/DN|blu/orn - pur/wht |A |REM *5 | | RADIO 12V|ORANGE / black |+ |radio | | RADIO GROUND|black |- |radio | | RADIO SWITCH|YELLOW /GREEN |+ |radio | Notes: NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 The DDM (drivers door module) is located in the center of the drivers door. *2 Requires a double pulse to unlock. *3 Parking lights require a negative trigger with a 1800 ohm resistor in-line to the WHITE/ green wire. Using a negative trigger with a 780 ohm resistor in-line to the same WHITE/ green wire will turn on the headlights as well as the parking lights. *4 This wire may cause the aftermarket alarm to false when the vehicles electrical system shuts down. Use a relay to isolate it. *5 The FEM (Front Electronic Module) is located in the drivers kick panel. The REM (Rear Electronic Module) is located in the trunk, just above the battery.
------------- Jeff
Posted By: Patel
Date Posted: December 08, 2002 at 12:25 PM
thanks for the info on the S-type, it could prove usefull. And no there was no typo, i need info on a 02 jag X-Type 3.0S
Date Posted: December 08, 2002 at 5:06 PM
Here is the 2002-2003 X-Type 3.0S | ITEM | WIRE COLOR |POL| WIRE LOCATION | | 12V|red |+ |ignition harness | | STARTER|yellow |+ |ignition harness | | IGNITION|GREEN/ orange |+ |ignition harness | | SECOND IGNITION|black (key sense) |+ |ignition harness | | ACCESSORY|GREEN / WHITE |+ |ignition harness | | POWER LOCK|green *1 |- |gry plug, pin 16 @ GECM *2 | | POWER UNLOCK|blue *1 |- |gry plug, pin 14 @ GECM *2 | | LOCK MOTOR|yellow/black | |grn plug, pin 3 @ GECM *2 | | UNLOCK MOTOR|WHITE/ green | |brn plug, pin 5 @ GECM *2 | | DISARM DEFEAT|WHITE/ black | |brn plug, pin 1 @ GECM *2 | | PARKING LIGHTS +|red | |pin 5 @ headlight switch | | PARKING LIGHTS -| | | | | HEADLIGHTS|GREEN/ black |- |pin 13 @ headlight switch | | DOOR TRIGGER|BLACK/ pink |- |gry plug, pin 3 @ GECM *2 | | DOME SUPERVISION|comes on with unlock| | | | TRUNK/HATCH PIN|brown |- |gry plug, pin 22 @ GECM *2 | | HOOD PIN|black |- |blu plug, pin 21 @ GECM *2 | |TRNK/HTCH RELEASE|blue |- |brn plug, pin 16 @ GECM *2 | | FCTRY ALARM ARM|arms with lock | | | |FCTRY ALRM DISARM|disarms with unlock | | | | DISARM NO UNLOCK| | | | | TACHOMETER|GREEN/ stripe | |any ignition coil | | SPEED SENSE|blue |8 |grn plug, pin 20 @ GECM *2 | | BRAKE WIRE|GREEN / WHITE |+ |brake pedal switch | | HORN TRIGGER|black |- |brn plug, pin 14 @ GECM *2 | | WIPERS|wht/grn(L),wht/blk(H|+ |steering column | | LF WINDOW UP/DN|*3 | | | | RF WINDOW UP/DN| | | | | LR WINDOW UP/DN| | | | | RR WINDOW UP/DN| | | | | SUN RF OPN/CLOSE|*3 | | | | SUN ROOF LIMIT| | | | | RADIO 12V|BROWN / white |+ |radio | | RADIO GROUND|black |- |radio | | RADIO SWITCH|YELLOW /GREEN |+ |radio | | RADIO ILLUMINATE|orange (dimmer) |+ |radio | | POWER ANTENNA| | | | | LF SPEAKER|white - yellow | |radio | | RF SPEAKER|wht/red - yel/red | |radio | | LR SPEAKER|wht/blu - yel/blu | |radio | | RR SPEAKER|wht/grn - yel/red | |radio | Notes: NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 These wires will meter while turning the key in the driver door key cylinder. *2 The GECM (General Electronic Control Module) is behind the glove box near the kick panel. *3 Interface of aftermarket window module is not possible because the motors are integrated with the control modules. However, an extended trigger on the door lock wire will roll the windows up and close the sunroof.
------------- Jeff
Posted By: kenny2002
Date Posted: December 13, 2002 at 11:20 PM
hi !Jeff Installer / Owner help me please...i really need wiring detail & intall manual for 2wss-as conpustar remote starter & alarm thanks
Date Posted: December 14, 2002 at 6:15 PM
Sorry, I can not access this information because it is for dealers only. Try to post this again .
------------- Jeff
