Need wiring diagram for Civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63385
Printed Date: May 17, 2024 at 2:00 PM
Topic: Need wiring diagram for Civic
Posted By: Allen_pytel
Subject: Need wiring diagram for Civic
Date Posted: September 27, 2005 at 9:57 PM
Wondering if nayone has a wiring diagram for a 2000 Honda Civic EX
Thanks Allen
Posted By: blazeronspokes
Date Posted: September 28, 2005 at 11:58 AM
ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness or *1      |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|yellow              |+  |ignition harness            |
|        ACCESSORY|WHITE/ black         |+  |ignition harness            |
|       POWER LOCK|GREEN / WHITE         |-  |keyless entry module *2     |
|     POWER UNLOCK|GREEN/ orange        |-  |keyless entry module *2     |
|       LOCK MOTOR|WHITE/ red           |   |drivers kick panel          |
|     UNLOCK MOTOR|blue/red            |   |drivers kick panel          |
|    DISARM DEFEAT|yellow/red          |   |keyless entry module *2     |
| PARKING LIGHTS +|RED / black           |   |keyless entry module *2     |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|lt. GREEN/ red       |-  |OEM alarm plug *3           |
| DOME SUPERVISION|same as doors       |   |                            |
|  TRUNK/HATCH PIN|blue/black          |-  |OEM alarm plug *3           |
|       TACHOMETER|blue                |   |test connector *4           |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|gray                |-  |OEM alarm plug *3           |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|RED / yel - RED / blu   |A  |drivers door switch         |
|  RF WINDOW UP/DN|blu/yel - blu/org   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|grn/yel - green     |A  |drivers kick panel          |
|  RR WINDOW UP/DN|yellow - yel/grn    |A  |drivers kick panel          |
Notes:
*1  In 6 pin white plug behind fuse box  *2 The keyless entry module is white in color, and located in the drivers kick panel.  *3 The OEM alarm plug is to the right side of the steering column.  The plug is green.  *4 Drivers side fire wall under hood in a 2 pin plug
Date Posted: September 28, 2005 at 12:20 PM
Wound u happen to have a stero wiring diagram for a 2000 civic as well? i should have put stero wiring diagram in my origional post
Posted By: thepencil
Date Posted: September 29, 2005 at 12:24 PM
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2000 / Audio
Radio 12v WHITE/ blue   +   radio harness
Radio Ground black   -   radio harness
Radio Ignition yellow/red   +   radio harness
Radio Illumination RED / black   +   radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- blue/green - gray/black   +,- radio harness
RF Speaker +/- RED / green - BROWN / black   +,- radio harness
LR Speaker +/- blue / YELLOW - gray/white   +,- radio harness
RR Speaker +/- RED / yellow - BROWN / white   +,- radio harness
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.posted_image
