2001 Chevrolet Silverado Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63905
Printed Date: May 17, 2024 at 7:40 PM
Topic: 2001 Chevrolet Silverado Alarm/Remote Start Wiring
Posted By: j68rh
Subject: 2001 Chevrolet Silverado Alarm/Remote Start Wiring
Date Posted: October 06, 2005 at 6:25 AM
Hey I need a wiring diagrame for a 2001 chevy silverado 1500 LS for a remote start alarm.
Posted By: mo12v
Date Posted: October 06, 2005 at 8:27 AM
OMEGA GM Passkey 3 & Passlock 2 Override Interface (DB-PASS-23A)
Constant 12 voltsRED & RED / WHITEIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightTAN(DR) GRY/BLK(PASS)PS (-) AT B.C.M. UNDER DRIVERS DASH *
Trunk Pin SwitchN/A
Parking LampL BLUE (+)AT HEADLIGHT SWITCH
Power LockL BLUEAT B.C.M. BELOW THE STEERING COLUMN
Power UnlockWHITEIN BROWN CONNECTOR
* TAN (-) In Connector On The Right Covers Driver Door Only. GRAY/BLACK (-) Connector On The Middle Cover Passengers Door. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires.
Positive Pulse Door Locks
Accessories
Window UpD\D BLUE P\ D BLUE @ SWITCH
Window DownR/BROWN S/ BROWN IN EACH DOOR
Ign Key WarnLT GREENIGNITION SWITCH HARNESS
Trunk ReleaseN/A
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsWHITE (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmL GREEN (-)AT B.C.M. BELOW THE STEERING COLUMN*
* There Are 3 Connectors In The BCM. The Disarm Wire Is Located In The Violet Connector
Reversal Rest At Ground Window Circuit
OEM Horn- Black (-) In Ignition Switch Harness
Remote Start
Tach SignalWHITEFOR THE V-8 AT THE P.C.M. *
Ignition #2WHITEIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS (HEAT/AC)
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)DRIVERS KICK PANEL
Rear Window DefrostN/A
* Power Control Module Located At The Left Front Of The Engine Compartment Pin 10 of the 80 pin connector. WHITE-For The V-6 At The Coil On Top Of The Engine. Glow Plug Wire(LT BLUE) At Engine Control Module. See Tech Notes For Alt.
Passlock II
MO
