Wiring Diagram 98 Nissan Maxima
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66378
Printed Date: May 02, 2024 at 2:43 AM
Topic: Wiring Diagram 98 Nissan Maxima
Posted By: dolfingirl1331
Subject: Wiring Diagram 98 Nissan Maxima
Date Posted: November 16, 2005 at 11:54 AM
Hello, I need a wiring diagram for a 98 Nissan Maxima
Posted By: boomer_106
Date Posted: November 16, 2005 at 8:25 PM
Here ya go. Nissan |
| Maxima |
| 1996 - 1999 |
| Remote Starter Wiring Colors and Notes | Function | Vehicle Color | Location | Start: | BLACK/ GREEN & BLK/WHT | | Ignition #1: | BLACK/ RED | IGNITION SWITCH HARNESS | Ignition #2: | RED / YELLOW | IGNITION SWITCH HARNESS | Ignition #3: | N/A | | Accessory: | WHITE/ BLUE | IGNITION SWITCH HARNESS | Brake Light: | RED / GREEN (+) | AT SWITCH ABOVE BRAKE PEDAL | Tach Signal: | WHITE/ GREEN | AT ENGINE CONTROL MODULE * | Parking Lights: | RED / GREEN (+) | AT HEADLIGHT SWITCH | Headlights: | GREEN/ YELLOW (DR) & | BLUE/BLACK (PS) (+) AT HEADLIGHT SW. | Diesel Glow Plug: | | | Clutch Bypass Wire: | | | Notes: | * Engine Control Module Located Behind Center Console. ** This Vehicle Is Equipped With Two Start Wires. Both Must Be Connected to Remtoes Starter Wire In Order For Vehicle To Start When Engine Is Cold; See Note #235 - Nissan Starter Wires Diagram For Co | Alarm and Keyless Entry Wiring Colors and Notes | Function | Vehicle Color | Location | Constant +12 Volts: | WHITE/ PURPLE | IGNITION SWITCH HARNESS | OEM Alarm Disarm: | GREEN/ YELLOW (-) | IN DRIVER DOOR (DRIVER SWITCH) | OEM Horn: | GREEN / WHITE (-) | STEERING COLUMN HARNESS | Power Lock: | LIGHT GREEN/ RED | AT LOCAL CONTROL UNIT (DR. SWITCH)**** | Power Unlock: | GREEN/ YELLOW | AT LOCAL CONTROL UNIT (DR. SWITCH)**** | Trunk Release: | PURPLE / YELLOW (-) | AT TRUNK RELEASE SWITCH | Alarm Input Wire: | RED / WHITE (-) | AT BODY CONTROL MODULE *** | Notes: | *** Body Control Module Located Behind Center Console Underneath A/T Control Module. RED / WHITE (-) Wire Also Found At Interior Fuse Panel. **** See Double Pulse Door Lock Diagram Note #231 , or program module for double pulse door locks. |
