2006 Chevrolet HHR Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67320
Printed Date: April 28, 2024 at 8:29 PM
Topic: 2006 Chevrolet HHR Alarm/Remote Start Wiring
Posted By: misterjimbo
Subject: 2006 Chevrolet HHR Alarm/Remote Start Wiring
Date Posted: November 30, 2005 at 9:38 AM
I lost my sheet for this and was wondering if someone could hook me up with the directechs info for it. thanks
Posted By: extreme1
Date Posted: November 30, 2005 at 12:34 PM
it's identical to a Cobalt.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: the12volt
Date Posted: November 30, 2005 at 12:41 PM
Posted By: mo12v
Date Posted: November 30, 2005 at 5:02 PM
Constant 12 voltsRED AT BCM CONN C3PIN D 12 *
Ignition 12 voltsSMALL BLUEIGNITION SWITCH HARNESS
StarterNO STARTER WIREUses Interface
Dome LightDR GRAY/BLK(-),PAS TAN/WHITE(-)IN EACH KICK PANNEL OR BCM*
Trunk Pin SwitchPINK/BLACK (-)AT BCM CONN C1 PIN 55 *
Parking LampBROWN (+) DR KICK ORWHITE (-) AT BCM CONN C1 PIN 8 *
Power LockWHITE AT BCM CONN C1PIN 7 (-) *
Power UnlockWHITE AT BCM CONN C1PIN 7 (-) WITH 1.5K *
GM Passlock  Interface  * The BCM (Body Control Module) Is Part Of The Fuse/Relay Box On The Front Passenger Side Of The Center Console.
Single Wire Resistor Door Locks or INTERFACE
Click Here For Our Databus & Immobilizer Bypass Cross Reference
Accessories
Window UpD\D BLUE P\D BLUE D\D BLUE P\D BLUE @ MASTER SWITCH
Window DownF/BROWN F/BROWN R/BROWN R/BROWN
Ign Key WarnWHITE
Trunk ReleaseWHITE/ BLACK (-)AT BCM CONN C1 PIN 69 *
OEM HornTAN (-)AT STEERING COLUMN HARNESS OR BCM *
HeadlightsPINK/WHITE (-) AT BCM*CONN C2 PIN 1 STEERING COLUMN HARNESS
OEM Alarm ArmRF ONLY
OEM Alarm DisarmRF ONLY
Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalWHITE OR ORANGE AT ECMIS ON THE DR SIDE FENDER FRONT **
Ignition #2
Ignition #3
AccessorySM BROWNAT IGNITION HARNESS
Neutral SafetyNA
Brake LightL BLUE (+)AT SWITCH OR BCM CONN C2 PIN 54 *
Reverse LightL GREEN (+)REAR HARNESS IN DRIVER OR PASS KICK
Rear Window DefrostWHITE (+) AT BCM CONNC1 PIN 16 *
** ECM (Engin Control Module) Is On The Drivers Side Of The Engine Compartment In Front Of The Under Hood Fuse Block.
MO
Date Posted: December 01, 2005 at 8:42 AM
thanks everyone.
