2003 Acura MDX wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6756
Printed Date: April 29, 2024 at 1:29 AM
Topic: 2003 Acura MDX wiring diagram
Posted By: queksong
Subject: 2003 Acura MDX wiring diagram
Date Posted: December 16, 2002 at 7:09 AM
Does anyone have the wiring diagram for the Acura MDX?  We appreciate the help.  Thanks
Posted By: Velocity Motors
Date Posted: December 16, 2002 at 12:20 PM
Here is the 2002 diagram which has not changed for the 2003:
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|yellow              |+  |ignition harness            |
|        ACCESSORY|WHITE/ black         |+  |ignition harness            |
|       POWER LOCK|BLACK/ orange        |-  |passenger mux unit *1       |
|     POWER UNLOCK|blue/orange         |-  |passenger mux unit *1       |
|       LOCK MOTOR|WHITE/ red           |   |passenger mux unit *1       |
|     UNLOCK MOTOR|yellow              |   |passenger mux unit *1       |
|    DISARM DEFEAT|lt. GREEN/ red       |   |passenger mux unit *1       |
| PARKING LIGHTS +|RED / black           |   |drivers kick panel          |
| PARKING LIGHTS -|RED / yellow          |   |headlight switch            |
|       HEADLIGHTS|blue/green          |-  |headlight switch            |
|     DOOR TRIGGER|BLACK/ white         |-  |interior light switch       |
| DOME SUPERVISION|                    |   |                            |
|  TRUNK/HATCH PIN|common with doors   |   |                            |
|         HOOD PIN|yellow              |-  |hood switch or *2           |
| DISARM NO UNLOCK|blue                |-  |drivers lock key cylinder   |
|       TACHOMETER|blue                |   |test connector *3           |
|      SPEED SENSE|blue/white          |   |under passenger seat *4     |
|       BRAKE WIRE|WHITE/ black         |+  |brake pedal switch          |
|     HORN TRIGGER|lt. GREEN/ blue      |-  |steering column             |
|           WIPERS|blue (L), blu/yel(H)|+  |steering column             |
|  LF WINDOW UP/DN|RED / blu - RED / yel   |A  |drivers window switch       |
|  RF WINDOW UP/DN|blu/wht - blu/yel   |A  |LF window switch in door    |
|  LR WINDOW UP/DN|RED / blu - RED / yel   |A  |LR window switch in door    |
|  RR WINDOW UP/DN|RED / blu - RED / yel   |A  |RR window switch in door    |
| SUN RF OPN/CLOSE|grn/yel - grn/red   |A  |relays in drivers kick panel|
|        RADIO 12V|white               |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|WHITE/ red           |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|    POWER ANTENNA|yellow/white        |+  |radio                       |
|       LF SPEAKER|blu/grn - gry/blk   |   |radio                       |
|       RF SPEAKER|RED / grn - brn/blk   |   |radio                       |
|       LR SPEAKER|blu/yel - gry/wht   |   |radio                       |
|       RR SPEAKER|RED / yel - brn/wht   |   |radio                       |
Notes:NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. *1 The passenger mux unit is attached to the passenger side fuse box in the passenger kick panel. *2 Also found at the drivers mux unit, which is attached to the driver side fuse box in the drivers kick panel. *3 The tach test connector is a 2 pin connector on the driver side fender. *4 In an 8 pin connector.
Posted By: queksong
Date Posted: December 16, 2002 at 1:29 PM
Thank you much.
Date Posted: December 17, 2002 at 1:48 AM
no problemo
