2003 Toyota Matrix Alarm Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6772
Printed Date: April 29, 2024 at 4:22 AM
Topic: 2003 Toyota Matrix Alarm Wiring
Posted By: o1cbc
Subject: 2003 Toyota Matrix Alarm Wiring
Date Posted: December 16, 2002 at 2:20 PM
can anyone help me. i'm installing a alarm in a 2003 toyota matrx and i was wondering if anyone had a wire diagram for this car.  Thank You.
brad
Posted By: Velocity Motors
Date Posted: December 17, 2002 at 1:47 AM
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white & black       |+  |ignition harness            |
|          STARTER|red                 |+  |ignition harness            |
|   SECOND STARTER|                    |   |                            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ white         |+  |ignition harness            |
|   THIRD IGNITION|                    |   |                            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
| SECOND ACCESSORY|                    |   |                            |
|       POWER LOCK|green *1            |-  |passenger kick panel        |
|     POWER UNLOCK|blue/black *1       |-  |passenger kick panel        |
|       LOCK MOTOR|blue                |   |driver kick, door harness   |
|     UNLOCK MOTOR|red                 |   |driver kick, door harness   |
|    DISARM DEFEAT|red                 |   |driver kick, harness to rear|
| PARKING LIGHTS +|green               |   |driver kick panel           |
| PARKING LIGHTS -|GREEN / WHITE         |   |headlight switch            |
|       HEADLIGHTS|red                 |-  |headlight switch            |
|     DOOR TRIGGER|RED / yellow          |-  |driver kick panel           |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|                    |   |                            |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|blue/white          |-  |release switch on dash      |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|*2                  |   |ignition coils              |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN / WHITE         |-  |steering column             |
Notes:*1 These are the passenger key cylinder wires. Meter the wires while turning the key in the passenger door. *2 Go to any one of the ignition coils under the black motor cover and use RED / blue, YELLOW /GREEN, gray, or white.
