2002 Chevrolet Avalanche Switched Ignition?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7365
Printed Date: May 03, 2024 at 7:13 AM
Topic: 2002 Chevrolet Avalanche Switched Ignition?
Posted By: dyer
Subject: 2002 Chevrolet Avalanche Switched Ignition?
Date Posted: December 29, 2002 at 11:59 AM
I would like to know the wiring colors for a 2002 avalanche. Really all I need is the remote wire, but all would be nice. Any help would be much appreciated.
Dyer
Posted By: dyer
Date Posted: December 30, 2002 at 8:29 AM
I"ll try an alternate route. Can anybody tell me the color of the switched ignition wire in a 2002 chevy? Please Help! Thanks
Dyer
Posted By: Velocity Motors
Date Posted: December 30, 2002 at 9:24 AM
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |brown plug at BCM *1        |
|     POWER UNLOCK|white               |+  |brown plug at BCM *1        |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan/black           |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |lt. blue plug at BCM *1     |
| PARKING LIGHTS -|white               |   |lt. blue plug at BCM *1     |
|       HEADLIGHTS|white               |+  |lt. blue plug at BCM *1     |
|     DOOR TRIGGER|*2                  |-  |BCM *1                      |
|FCTRY ALRM DISARM|lt.green            |-  |drivers kick *4             |
|       TACHOMETER|white               |   |ECM *3                      |
|      SPEED SENSE|dk.GREEN / WHITE      |   |ECM *3                      |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |brown plug at BCM *1        |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue   -   brown    |A  |drivers door switch         |
|  RF WINDOW UP/DN|blue   -   brown    |A  |passenger door switch       |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. *1 The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.  *2 Use tan for the drivers door located in pin B4 of the purple plug, and for the passenger door it will be a orange in pin B2 in the purple plug or dk.blue/white in pin B11 of the lt.blue plug, must diode isolate these wires.  *3 ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the 'red' connector, and VSS wire is located in pin 50 of the 'red' connector.  *4 Also found in the purple plug of the BCM.
Date Posted: December 30, 2002 at 9:31 AM
It will be the PINK wire in any Chevy at the ignition harness. There is not one behind the stereo.... they took it out a couple of years back.
Posted By: dyer
Date Posted: December 30, 2002 at 11:14 AM
Thanks for your help. Just out of curiosity.. Why did they remove it?
Dyer
Posted By: dyer
Date Posted: December 30, 2002 at 11:17 AM
I do appreciate everything!!
Dyer
Date Posted: December 30, 2002 at 1:26 PM
I guess they only need the OBDII data wire to control all the functions of the stereo when ignition is feed through the system. My other guess would be because they just wanted to posted_image
