2001 GMC Sierra Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7482
Printed Date: May 02, 2024 at 1:00 AM
Topic: 2001 GMC Sierra Alarm/Remote Start Wiring
Posted By: gr8shade
Subject: 2001 GMC Sierra Alarm/Remote Start Wiring
Date Posted: January 01, 2003 at 1:17 PM
require wiring diagram for 2001 GMC Sierra Z71, also does this truck use the 3 wire positive door lock configuration & will I need to add door lock relays?
Thanks in advance
gr8shade
Posted By: Velocity Motors
Date Posted: January 01, 2003 at 4:22 PM
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |brown plug at BCM *1        |
|     POWER UNLOCK|white               |+  |brown plug at BCM *1        |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan/black           |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |lt. blue plug at BCM *1     |
| PARKING LIGHTS -|white               |   |lt. blue plug at BCM *1     |
|       HEADLIGHTS|white               |+  |lt. blue plug at BCM *1     |
|     DOOR TRIGGER|*2                  |-  |BCM *1                      |
|FCTRY ALRM DISARM|lt.green            |-  |drivers kick *4             |
|       TACHOMETER|white *5            |   |ECM *3                      |
|      SPEED SENSE|dk.GREEN / WHITE      |   |ECM *3                      |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |brown plug at BCM *1        |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue   -   brown    |A  |drivers door switch         |
|  RF WINDOW UP/DN|blue   -   brown    |A  |passenger door switch       |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
NOTE:  This vehicle has the passlock II immobilizer system*1 The BCM is located behind the drivers side of the dash.  The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.  *2 Use tan for the drivers door located in pin B4 of the purple plug, and for the passenger door it will be a orange in pin B2 in the purple plug or dk.blue/white in pin B11 of the lt.blue plug, must diode isolate these wires.  *3  ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red, and VSS wire is at pin 3 in the connector labeled black. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector, and VSS wire is located in pin 50 of the red connector.  *4  Also found in the purple plug of the BCM.  *5 Diesel tach wire is white at the cluster. Diesel wait to start wire is dk. blue (-) located at the instrument cluster.
