Audi A4 schematic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77035
Printed Date: April 28, 2024 at 3:35 AM
Topic: Audi A4 schematic
Posted By: billsmith7
Subject: Audi A4 schematic
Date Posted: April 29, 2006 at 11:31 PM
Does anyone have the schematic for a 2004 Audi A4?
Posted By: infinkc
Date Posted: May 01, 2006 at 10:27 PM
12volts red (x2)(common 150A) + ignition harness
Starter RED / black + ignition harness
Second Starter blue or RED / black + ignition harness
Ignition black + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow/black + ignition harness
Second Accessory N/A
Keysense red + ignition harness
Power Lock blue/white - driver door module in door
Power Unlock PURPLE / green (double pulse) - driver door module in door
Lock Motor BROWN / blue or gray/blue 5wi driver door module in door
Unlock Motor gray/green 5wi driver door module in door
Parking Lights+ gray + headlight switch
Notes: May have to interrupt the purple wire at the headlight switch in order for the lights to work.
Parking Lights- N/A
Hazards RED / yellow - hazard light switch
Turn Signal(L) BLACK/ blue (F), GREEN/ blue (R) + vehicle electrical system ctrl mod
Notes: The vehicle electrical system control module is under the driver side dash.
Turn Signal(R) GREEN/ blk (F), yellow/grn (R) + vehicle electrical system ctrl mod
Reverse Light blue/red + CCM, conn 3, pin 7
Notes: The CCM (Central Control Module for comfort system) is mounted on the floorpan in a protective box, under the carpet in front of the driver seat.
Door Trigger use dome supervision wire
Dome Supervision BROWN / white - CCM, conn 1, pin 2
Trunk/Hatch Pin WHITE/ yellow - CCM, conn 5, pin 11
Hood Pin BROWN / purple - CCM, conn 4, pin 20
Trunk/Hatch Release yellow/red 5wi CCM, conn 1, pin 6
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer NOT RED / blue or BLACK/ blue ac any fuel injector
Wait to start N/A
Brake Wire RED / black + brake pedal switch
Parking Brake BROWN / white - CCM, conn 3, pin 2
Horn Trigger BLACK/ white + driver kick, red 17 pin plug
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
Combo Interface Required:
Yes Type:
Data Bus
Part #: CAN1
------------- There are 10 types of people in the world, ones that understand binary and ones that dont.
