1999 Infiniti Alarm Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7751
Printed Date: May 17, 2024 at 5:06 PM
Topic: 1999 Infiniti Alarm Diagram
Posted By: tedng5
Subject: 1999 Infiniti Alarm Diagram
Date Posted: January 06, 2003 at 5:02 PM
I was unable to find in Installer's bay Alarm Information on 1999 Infiniti I30.   Door unlock, lock and door trigger colors is required.    Does anyone have??
Posted By: Montrealler
Date Posted: January 06, 2003 at 5:29 PM
       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|wht/red or wht/pur  |+  |ignition harness            |
|          STARTER|blk/yel or blk/wht  |+  |ignition harness            |
|   SECOND STARTER|grn/blk or RED / blu  |+  |ignition harness            |
|         IGNITION|blk/wht or blk/red  |+  |ignition harness            |
|        ACCESSORY|RED / yel or red      |+  |ignition harness            |
| SECOND ACCESSORY|blue or wht/blu     |+  |ignition harness            |
|       POWER LOCK|lt. GREEN/ red       |-  |in drivers door at switch   |
|     POWER UNLOCK|GREEN/ YELLOW *1     |-  |in drivers door at switch   |
|       LOCK MOTOR|BROWN / white         |   |in drivers door at switch   |
|     UNLOCK MOTOR|brown               |   |in drivers door at switch   |
|    DISARM DEFEAT|brown               |   |in passenger door at switch |
| PARKING LIGHTS +|RED / green           |   |steering column             |
|       HEADLIGHTS|gry/yel(L)blu/blk(R)|+  |steering column             |
|     DOOR TRIGGER|RED / white           |-  |low in drivers kick         |
|  TRUNK/HATCH PIN|purple / YELLOW       |-  |drivers kick or BCM *2      |
|         HOOD PIN|yellow/black        |-  |BCM *2                      |
|TRNK/HTCH RELEASE|purple / YELLOW       |-  |low drivers kick *3         |
|  FCTRY ALARM ARM|arms w/ lock        |   |                            |
|FCTRY ALRM DISARM|disarms w/ unlock   |   |                            |
| DISARM NO UNLOCK|*4                  |   |                            |
|       TACHOMETER|WHITE/ green         |   |ECM *5                      |
|       BRAKE WIRE|RED / green           |+  |at brake switch             |
|     HORN TRIGGER|GREEN / WHITE         |-  |                            |
|           WIPERS|lt. GREEN/ red       |-  |steering column             |
|  LF WINDOW UP/DN|blu/red - blu/blk   |A  |in LF door at switch        |
|  RF WINDOW UP/DN|blu/red - blu/blk   |A  |in RF door at switch        |
|  LR WINDOW UP/DN|blu/red - blu/blk   |A  |in LR door at switch        |
|  RR WINDOW UP/DN|blu/red - blu/blk   |A  |in RR door at switch        |
Notes:
Note: The ignition harness wires change color at a plug. The above listed colors show both sides of the plug.  *1 Requires a double pulse.  *2 The BCM (body control module) is located just below the radio.  *3 Must use a relay to interface with this circuit.  *4 A single negative pulse to the unlock wire will disarm without unlocking.  *5 The ECM is located in the front of the center console on the transmission hump. The wiring is easily reached by removing the small black panel just to the front of the center console on the passenger side. the wire is in the middle row, 7th one in from the left.
Yes I'm Back 2006...
