Hi all, looking for 2002 Acura 1.7 EL remote start + alarm information. Thanks for any help.
john
Remote Starter Wiring Colors and Notes |
Function | | DTI Color | Vehicle Color | Location |
Start: | | Yellow | BLACK/ White | Ignition Switch Harness* |
Ignition #1: | | Blue | BLACK / YELLOW | Ignition Switch Harness |
Ignition #2: | | Green | N/A | not needed |
Ignition #3: | | Wht/Blk | N/A | **** |
Accessory: | | White | BLACK/ Red | ign |
Brake Light: | | Orange | WHITE/ Black | At Brake Switch |
Tach Signal: | | Green | Blue | At Coil Pack |
Parking Lights: | | Yellow | RED / Yellow or Blue | At Light Switch*** |
Headlights: | | Yellow | N/A | not recommended |
OEM Alarm Disarm: | | Brn/Wht | WHITE/ Red | At Module Near Drivers Kick Panel |
OEM Alarm Arm: | | n/a | White | At Module Near Drivers Kick Panel |
Diesel Glow Plug: | | RED / Black | N/A | Not Applicable |
Clutch Bypass Wire: | | n/a | No Color Available | Please call with information |
Notes: | | *Equipped with transponder-anti-theft system - Use Universal Alarm Bypass Module. *** Must test parking lights. May be positive or negatice depending on the location you are attaching to the wire. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | Red | White | Ignition Switch Harness* |
Starter Kill: | | Vlt or Wht | BLACK/ White | Ignition Switch Harness* |
Ignition +12 Volts: | | Orange | BLACK / YELLOW | Ignition Switch Harness |
Dome Lights/Superv: | | Brown | No color available | Please call with information |
OEM Horn: | | Blue | No Color Available | Please call with information |
Power Lock: | | Wht/Red | WHITE/ Blue | At Module Near Drivers Kick Panel** |
Power Unlock: | | Yel/Red | WHITE/ Green | At Module Near Drivers Kick Panel |
Trunk Release: | | Grn/Wht | YELLOW /GREEN | At Module Near Drivers Kick Panel |
Alarm Input Wire: | | R/W or Gy/Bk | No color available | Please call with information |
Notes: | | *Use constant power only for alarm or keyless modules, never remtoe start. ** Horn can also be found as an Orange in the Steering Column Harness. Note: Factory hood pin is GREEN/ Black at module near Driver Kick Panel. |
thanks.
