2006 VW Passat Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83019
Printed Date: March 05, 2026 at 5:01 AM
Topic: 2006 VW Passat Alarm/Remote Start Wiring
Posted By: draeger
Subject: 2006 VW Passat Alarm/Remote Start Wiring
Date Posted: September 17, 2006 at 9:27 PM
Anyone have a wiring diagrams for a 2006 Volkswagen Passat, I will be installing a Viper alarm in my friends and haven't done a install on the newier VW models, just 2002 and earlier. Main things I need are 12v, remote, start and horn. Any help would be great.
Posted By: gcorrea
Date Posted: September 17, 2006 at 10:08 PM
12volts
      red (x2)
      ignition harness
Starter      RED / black       +       ignition harness
Second Starter      N/A
Ignition      black       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      yellow/black       +       ignition harness
Second Accessory      N/A
Keysense      red       +       ignition harness
Power Lock      RED / green       -       driver door module in door
Power Unlock      RED / blue (double pulse)       -       driver door module in door
Lock Motor      BLACK/ blue       5wi      driver door module in door
Unlock Motor      BLACK/ gray       5wi      driver door module in door
Parking Lights+      GREEN/ red       +       headlight switch
Parking Lights-      N/A
Hazards      same as turn signal wires
Turn Signal(L)      BLACK/ white       +       comfort module, 15 pin plug, pin 15
Turn Signal(R)      BLACK/ green       +       comfort module, 15 pin plug, pin 14
Reverse Light      blue/red       +       driver kick, harness to rear
Door Trigger      BROWN / yellow       -       comfort module, 23 pin plug, pin 1
Dome Supervision      blue/gray       -       comfort module, 23 pin plug, pin 21
Trunk/Hatch Pin      BROWN / black       -       comfort module, 23 pin plug, pin 10
Hood Pin      BROWN / red       -       comfort module, 15 pin plug, pin 5
Trunk/Hatch Release      BROWN / gray to BROWN / green       -       comfort module, 23 pin plug, pin 2
Power Sliding Door      N/A
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      disarms with unlock
Disarm No Unlock
Tachometer      NOT blk/blue or grn/red (W8)       ac       any fuel injector
Wait to start      N/A
Brake Wire      RED / black       +       brake pedal switch
Parking Brake      BROWN / white       -       parking brake switch
Horn Trigger      BLACK / YELLOW (alarm horn)       +       comfort module, 15 pin plug, pin 11
Memory Seat 1      yellow/black       -       memory switch on driver seat
Memory Seat 2      yellow/red       -       memory switch on driver seat
Memory Seat 3      yellow/blue       -       memory switch on driver seat
Interface Modules
Smart Starter Kill Relays
MAKE : VOLKSWAGEN | MODEL : PASSAT | YEAR : 2004
* The logo is registered trade mark of Volkswagen Corporate.
Copyright © 2000-2006 Directed Electronics, Inc. All Rights Reserved. Revised: 25 March 2006
This website is for the sole use of authorized DEI personel and it's participating installers and retailers. The information contained on these pages may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited.
Having trouble using this site? Let us know - webmaster@directechs.com
hope this helps
gcorrea
Posted By: draeger
Date Posted: September 18, 2006 at 12:17 AM
Hey anything will help at this point lol. Thanks for the promptness on the info because I will be doing it tomorrow. I'll make note of what is what color and where if anything defers from the info you provided.
Thanks,
Chris
Posted By: draeger
Date Posted: September 24, 2006 at 6:46 PM
12v - RED / white thicl gauge wire at the bottom of the relay box
Remote - black    "            "               "
Starter - RED / blue thick gauge wire at interior firewall
Horn - black thin gauge wire at the bottom of the relay box behind the horn relay
Posted By: KarTuneMan
Date Posted: September 24, 2006 at 9:51 PM
Remote start / security / GPS
Wire/Function Colour Location/Description Polarity
PASSIVE ANTI-THEFTYESTRANSPONDER (Bypass or Data module required) SEE NOTES
This vehicle is equipped with an IMMOBILIZER passive anti-theft system. Please refer to the diagram for proper bypass instructions.
12 VOLTSRedBehind the fusebox on the left side of the dash +
IGNITIONRED / bluePin-4 on Ignition switch connector +
See the provided document for exact pin locations.
IGNITION 2GREEN/ gray & GreenPin-12 and Pin-1 on Ignition switch connector +
STARTERRED / grayPin-3 on Ignition switch connector +
STARTER 2RED / grayPin-11 on Ignition switch connector +
KEY SENSEGreenPin-1 on Ignition switch connector +
This wire is required for remote start and should be energized before ignition.
LOCKWhite (1-3)At module in driver's door -
1-wire system. Straight ground (-) to lock and ground through 180-ohm resistor to unlock.
UNLOCKWhite (1-3)At module in driver's door -
TRUNK RELEASEGREEN/ blackIn driver's door at switch -
FACTORY ARMArms with lock
FACTORY DISARMThrough OEM remote only
Alarm will disarm automatically on remote start when the transponder is detected.
BRAKESWITCHRED / blackIn the driver's kickpanel +
PARKLIGHTSRED / blue & WHITE/ blackAt the lightswtch in the dash
This requires so special wiring, please refer to the parklight diagram.
