2006 Mazda MPV, remote start wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83345
Printed Date: May 05, 2024 at 4:19 AM
Topic: 2006 Mazda MPV, remote start wiring
Posted By: maurous
Subject: 2006 Mazda MPV, remote start wiring
Date Posted: September 25, 2006 at 9:11 PM
wiring info on this vehicle?remote start? Thanks
If you see sparks, it might not be the love in the air but the car going on fire.
Posted By: maurous
Date Posted: September 28, 2006 at 3:08 PM
Guys nobody knows which type of bypass kit this unit requires?
Posted By: josh1979
Date Posted: September 28, 2006 at 8:23 PM
12volts WHITE/ black (60A), red (40A)  +  ignition harness
Starter blue / YELLOW  +  ignition harness
Second Starter N/A
Ignition blue  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red  +  ignition harness
Second Accessory BLACK/ white  +  ignition harness
Keysense white  +  ignition harness
Notes: Using the status output from the remote start to trigger a relay to power this wire will disarm the alarm without unlocking the doors.
Power Lock green  -  keyless module below column
Notes: Lock is negative trigger thru a 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock same as power lock wire
Lock Motor red  5wi door lock module in passenger kick
Unlock Motor blue  5wi door lock module in passenger kick
Parking Lights+ lt. GREEN/ black  +  driver kick, harness to rear
Parking Lights- BROWN / white  -  headlight switch
Hazards blue  -  keyless module below column
Turn Signal(L) BLACK/ white  +  turn signal switch
Turn Signal(R) blue/red  +  turn signal switch
Reverse Light RED / yellow  +  driver kick, harness to rear
Door Trigger BLACK/ red  -  keyless module below column
Dome Supervision use door trigger wire
Trunk/Hatch Pin common with door trigger wire
Hood Pin BROWN / yellow  -  theft module left of column
Trunk/Hatch Release N/A
Power Sliding Door pink/blue (L), WHITE/ green (R) -  power sliding door switch on dash
Notes: Power sliding door open is a straight negative trigger. Close is negative trigger thru a 2,000 ohm resistor. MUST use relays.
Factory Alarm Arm lt. green  -  keyless module below column
Notes: Arm is negative trigger thru a 1,000 ohm resistor. Disarm is a straight negative trigger. MUST use relays.
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock use key sense wire
Tachometer PURPLE / white  ac  data link connector
Notes: The data link connector is under the hood on the driver side shock tower.
Wait to start N/A
Brake Wire GREEN/ YELLOW  +  brake pedal switch
Parking Brake green or brown  -  parking brake switch
Horn Trigger GREEN/ red  -  keyless module below column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
posted_image
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
Door Lock Interface
Required:
Yes
Type:
Multiplex
Part #: 456LW
Notes:
posted_image
Smart Starter Kill Relays: Not Availa
bring back the rotary phone so i dont have to press 1 to proceed in english
