2004 Toyota Corolla Speaker Color codes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84838
Printed Date: May 09, 2024 at 6:23 PM
Topic: 2004 Toyota Corolla Speaker Color codes
Posted By: andrewn721
Subject: 2004 Toyota Corolla Speaker Color codes
Date Posted: October 30, 2006 at 2:30 AM
hey im new to this site but i was wondering if any of you guys know the color codes for the wires behind the deck are. like which one is left and right front rear speaker, remote an antenna wire, etc. thanks!
Posted By: KarTuneMan
Date Posted: October 30, 2006 at 8:07 AM
+12V DC Battery(Constant) | Blue/white | | Dome | 15 Amp | In engine room junction block | Switched Accessory | Gray | | Cig | 15 Amp | Junction box behind left side of dash, at lower finish panel. | Ground | Brown | | Power Antenna | Black | | Illumination | Green & WHITE/ black | | Left Front + | Pink | | Left Front - | Violet | | Right Front + | Light green | | Right Front - | Blue | | Left Rear + | Black | | Left Rear - | Yellow | | Right Rear + | Red | | Right Rear - | White | |
AT SPEAKERS | |
Wire Function | Color | Note | Left Front Tweeter + | Light green | If equipped | Left Front Tweeter - | Blue | If equipped | Right Front Tweeter + | Light green | If equipped | Right Front Tweeter - | Blue | If equipped |
Date Posted: October 30, 2006 at 5:34 PM
man thanks so much and do you know which one i tap the remote wire into?
Posted By: Mike M2
Date Posted: October 30, 2006 at 7:14 PM
The black power antenna wire. This will make the factory antenna amplifier work. Without it you won't get any stations...
------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: October 31, 2006 at 2:01 AM
i actually tap'ed the remote wire into the accesory wire(gray) and the amplifier turned on. i didnt know about the radio station thing so i should check if i pick up radio...i just had a cd in there.
also, behind the deck theres 8 speaker wires. 2 Front +/- and 2 Rear +/-. my high low converter only had 4 wires and the diagram directed me to one into a +/- right speaker and a +/- left speaker. which speaker wires am i suppose to tap to.
