01 Mercedes Benz CLK320
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8883
Printed Date: May 07, 2024 at 8:23 PM
Topic: 01 Mercedes Benz CLK320
Posted By: thms
Subject: 01 Mercedes Benz CLK320
Date Posted: January 31, 2003 at 1:58 PM
Need Wire info for alarm
Posted By: jayts95
Date Posted: January 31, 2003 at 7:05 PM
|              12V|red                 |+  |ignition harness            |
|          STARTER|purple              |+  |ignition harness            |
|         IGNITION|pink/red            |+  |ignition harness            |
|  SECOND IGNITION|pink / YELLOW         |+  |ignition harness            |
|   THIRD IGNITION|BLACK/ green         |+  |ignition harness            |
|       POWER LOCK|black               |-  |driver door module or *1    |
|     POWER UNLOCK|blue                |-  |driver door module or *1    |
| PARKING LIGHTS +|gry/red & gry/blk *5|   |illumin. control module *5  |
|       HEADLIGHTS|yellow & yel/blk    |5wi|illumin. control module *5  |
|     DOOR TRIGGER|*2                  |-  |pin switches or *1          |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|BROWN / yellow        |-  |trunk light or *1           |
|         HOOD PIN|BROWN / red           |-  |hood switch or *1           |
|TRNK/HTCH RELEASE|yellow              |-  |release switch or *1        |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
|       TACHOMETER|*4                  |   |ignition coils              |
|      SPEED SENSE|GREEN/ black         |   |radio                       |
|       BRAKE WIRE|black or blk/wht    |+  |brake pedal switch          |
|     HORN TRIGGER|                    |   |                            |
|           WIPERS|yel/wht & yel/gry   |+  |wiper motor                 |
|  LF WINDOW UP/DN|*3                  |   |                            |
|  RF WINDOW UP/DN|                    |   |                            |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|*3                  |   |                            |
Notes:
NOTE:  Vehicles with the switchblade key have an immobilizer system that needs to be bypassed when adding remote start.  Use DEI part number 555U. Vehicles with the Smart Key, a bypass is not available at this time.  *1 Also found at the alarm module. The alarm is integrated in the Pneumatic System Equipment (PSE) control module in the passenger side of the trunk.  *2 The driver door trigger is BROWN / gray, and the passenger door trigger is BROWN / blue.  *3 Extended triggers on the door lock wires will roll the windows up/down and open/close the sunroof. Use validity channels to control.  *4 There are individual coils for each cylinder. Go to any one and use the wire that is NOT BLACK / YELLOW or BLACK/ green.  *5 The illumination control module is attached to the back of the headlight switch. The parking lights and headlights must be relay isolated from the control module.
