I am pretty sure its like the fusion but anybody got documents on this vehicle? also were is the best place to bring power from battery inside the vehicle? Thanks!
Nothing like the fusion.
12volts red(30A) + ignition harness
Starter dk. green + ignition harness
Second Starter N/A
Ignition lt. GREEN/ purple + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW + ignition harness
Second Accessory N/A
Keysense yellow + ignition harness
Power Lock pink / YELLOW - driver kick or SJB, conn. C, pin 3
Power Unlock pink/lt. green - driver kick or SJB, conn. C, pin 18
Lock Motor pink/black 5wi driver kick or SJB, conn. E, pin 13
Unlock Motor yellow 5wi driver kick or SJB, conn. E, pin 6
Parking Lights+ BROWN / white + driver kick or SJB, conn. E, pin 22
Parking Lights- BLACK/ lt. green - switch or SJB, conn. D, pin 26
Hazards WHITE/ red - switch or SJB, conn. D, pin 23
Turn Signal(L) gray/black (F), WHITE/ red (R) + SJB, conn. A, pin 11; conn. E, pin 5
Turn Signal(R) dk blu/org (F), gry/lt blu (R) + SJB, conn. A, pin 3; conn. E, pin 10
Reverse Light WHITE/ yellow + driver kick or SJB, conn. E, pin 18
Door Trigger use dome supervision wire
Dome Supervision BLACK/ lt. blue + dr. A pillar or SJB, conn. E, pin 7
Trunk/Hatch Pin WHITE/ purple - driver kick or SJB, conn. C, pin 5
Hood Pin PURPLE / orange - pin switch or SJB, conn. A, pin 6
Trunk/Hatch Release pink/orange - switch or SJB, conn. D, pin 10
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. blue/black - driver kick or SJB, conn. C, pin 4
Disarm No Unlock see factory alarm disarm
Tachometer NOT red ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire RED / lt. green + switch or SJB, conn. A, pin 8
Parking Brake RED / yellow - switch or SJB, conn. C, pin 23
Horn Trigger dk. blue - switch or SJB, conn. B, pin 7
Memory Seat 1 BLACK/ lt. grn or BROWN / lt. grn - driver seat module under seat
Memory Seat 2 BLACK/ orange - driver seat module under seat
Memory Seat 3 N/A
