2000 jeep grand cherokee rem start w555cw
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90369
Printed Date: June 14, 2024 at 12:57 PM
Topic: 2000 jeep grand cherokee rem start w555cw
Posted By: m3mn
Subject: 2000 jeep grand cherokee rem start w555cw
Date Posted: February 12, 2007 at 2:28 AM
hello, I am confused on setting up my inwells 3506 remote start, I have read many other posts but cant figure this out for my unit, the wires i am not sure about are H2/3 y/g CH2 out -300ma they suggest for a trunk, H2/4 r/b CH1 out -300ma it says connect to 12V+ if it is an auto, could this be right? for the same wire it says Dome output, Caller output, or when system arming will output 30 sec or 12 sec according to different window closer module. H2/6 w/b status output - this says it supplies a -300ma output as soon as the module begins remote start process, is this what i connect the 555cw to? do i need a relay? and as far as i can find this jeep is neg trigger for the locks, this unit can do either the diagram for neg trigger has or/wh=cut; green=close sign; yel/wh=(-); or/blk=cut; blue=open sign; yel/black=(-), Can anyone help me know what to hook up where? thanks in advance
Posted By: Velocity Motors
Date Posted: February 12, 2007 at 8:38 AM
This you can use for any device that requires a pulsed output. You can add a relay to convert the polarity to a (+) input device as well.
This wire sounds like a (-) when armed wire or a dome light surveillance wire depending on how you program this wire. Check to see how you can program this wire, but if you do not use it it may not matter.
This would connect to the 555CW module. This is considered your STATUS output wire.
Use ORANGE / black and pink/black at the driver door lock switch in the door to lock and unlock the driver door. Use ORANGE / purple and pink/purple at the passenger door lock switch in the door to lock and unlock all of the other doors. These wires are reverse polarity (5 wire).
Posted By: m3mn
Date Posted: February 14, 2007 at 12:15 PM
the directions for the 555cw say once its programmed you only need the 12V connected is that true?
Posted By: m3mn
Date Posted: February 16, 2007 at 10:22 PM
I guess im unclear how the lock wiring goes with my alarm, it has no reverse polarity config diagram, Internally it says
NC=or/wh
c=green
no=yel/white
nc=or/black
com=blue
no=yel/blk
There is wiring for pos and neg trigger
or/wh=-
green=motor
yel/white=12v
or/blk=-
blue=motor
yellow/black=12v
is this what i use?
Posted By: m3mn
Date Posted: February 17, 2007 at 3:29 PM
And do I have to cut the factory wiring to the lock motor?
Posted By: dksob81
Date Posted: February 21, 2007 at 8:06 PM
I am having a simlar problem in my 98 Grand Cherokee, it has keyless entry (factory), I just installed a Remote Starter/Alarm/Keyless entry system, I got the remote starter working but am having trouble with hooking up the keyless entry (aftermarket) part.
There are 6 wires for the keyless entry system,
Unlock - BROWN / Black (Normally Open  input)
Lock - WHITE/ Black (Normally Open  input)
Unlock - Violet (Normally Closed)
Lock - Violet/Black (Normally Closed)
Unlock - Blue/Black (Common  ouput)
Lock - GREEN/ Black (Common  output)
Can anyone Please help, what wires do I hook where to get this system working, I hate having to use both the remotes (1 for starting the jeep and the other to unlock/lock the jeep.
Please email me if you can or have any ideas..
Joe
dksob81@hotmail.com
