Wanted: Wire diagrams Montero/Eclipse/Corolla
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9049
Printed Date: May 15, 2024 at 9:51 PM
Topic: Wanted: Wire diagrams Montero/Eclipse/Corolla
Posted By: sfowler
Subject: Wanted: Wire diagrams Montero/Eclipse/Corolla
Date Posted: February 04, 2003 at 10:09 AM
I know people have access to diagram databases.
Could I get the them for:
2000 Mitsubishi Montero Sport XLS
2000 Mitsubishi Eclipse GT
1994 Toyota Corolla DX
Thanks in advance,
-Steve
steven_m_fowler@yahoo.com
Posted By: BNLUIS
Date Posted: February 04, 2003 at 11:22 AM
2000 Montero Sport
 ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+  |ignition harness            |
|          STARTER|blk/yel or blk/blu  |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
| SECOND ACCESSORY|blue                |+  |ignition harness            |
|       POWER LOCK|BLACK/ red *1        |-  |right rear side of fuse box |
|     POWER UNLOCK|BLACK/ blue *1       |-  |right rear side of fuse box |
| PARKING LIGHTS +|GREEN / WHITE         |   |headlight switch            |
|       HEADLIGHTS|red                 |-  |headlight switch            |
|     DOOR TRIGGER|GREEN/ red           |-  |top of fuse box *2          |
|  TRUNK/HATCH PIN|tied in with door   |   |                            |
|         HOOD PIN|                    |   |                            |
|  FCTRY ALARM ARM|blue / YELLOW         |-  |drivers kick panel          |
|FCTRY ALRM DISARM|BLACK/ red           |-  |drivers kick panel          |
|       TACHOMETER|wht/blk or white    |   |coil or ignition module *3  |
|      SPEED SENSE|yellow/white        |   |data link connector *4      |
|       BRAKE WIRE|green               |+  |brake switch                |
|     HORN TRIGGER|green               |+  |horn or relay underhood     |
|           WIPERS|blu/red(L),blu/blk(H|+  |steering column             |
|  LF WINDOW UP/DN|red - green         |A  |drivers door switch         |
|  RF WINDOW UP/DN|RED / blu - blk/yel   |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|RED / wht - grn/wht   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|RED / wht - grn/wht   |A  |drivers switch or kick panel|
| SUN RF OPN/CLOSE|blu/wht - blue      |A  |motor at front of sunroof   |
| RADIO ILLUMINATE|GREEN/ blue          |+  |radio                       |
|    POWER ANTENNA|WHITE/ black         |+  |radio                       |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.  Use DEI module 555U to bypass.  *1 Warning! When doing door locks on these trucks make sure you DO NOT cycle the door locks rapidly. This may cause the ETACS module to fail and the door locks will no longer work. Also, you MUST add diodes to the lock and unlock output from our units to prevent damage to the ETACS. Make sure you insert the diodes with the cathode (stripe side) towards our unit.  *2 In a 2 pin plug.  Also found in the drivers A pillar.  *3 On the 2.4L, tach is wht/blk at the coil on the left front of the engine compartment. On the 3.0L and 3.5L it is white at the ignition module next to the coils on the right rear side of the engine compartment under the plastic motor cover.  *4 The data link connector is under the driver side dash, near the relay box.
2000  Eclipse
|              12V|WHITE/ red           |+  |ignition harness            |
|          STARTER|BLACK/ red           |+  |ignition harness            |
|         IGNITION|dk. green           |+  |ignition harness            |
| SECOND ACCESSORY|blue/black          |+  |ignition harness            |
|       POWER LOCK|lt. GREEN/ black *2  |-  |drivers kick panel *1       |
|     POWER UNLOCK|orange *2           |-  |drivers kick panel *1       |
|       LOCK MOTOR|lt. green           |   |drivers kick panel *1       |
|     UNLOCK MOTOR|dk. GREEN/ red       |   |drivers kick panel *1       |
|    DISARM DEFEAT|blue/black          |   |passenger kick panel or *9  |
| PARKING LIGHTS +|grn/wht or pnk/blk  |   |low in drivers kick         |
|       HEADLIGHTS|orange              |-  |headlight relay under hood  |
|     DOOR TRIGGER|GREEN/ YELLOW        |-  |fuse box *8                 |
| DOME SUPERVISION|GREEN/ orange        |-  |fuse box *3                 |
|  TRUNK/HATCH PIN|red                 |-  |drivers kick panel *7       |
|TRNK/HTCH RELEASE|GREEN / WHITE         |5wi|drivers kick panel *7       |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|*6                  |   |                            |
|       TACHOMETER|*4                  |   |*4                          |
|      SPEED SENSE|WHITE/ blue          |   |center console *5           |
|       BRAKE WIRE|GREEN/ orange        |+  |brake pedal switch          |
|     HORN TRIGGER|lt. GREEN/ black     |-  |steering column             |
|           WIPERS|blu/org & blu/yel   |+  |wiper motor                 |
|  LF WINDOW UP/DN|RED / blk - grn/blk   |A  |drivers window switch       |
|  RF WINDOW UP/DN|RED / wht - green     |A  |drivers kick panel *1       |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|ORANGE / black        |+  |radio                       |
|     RADIO SWITCH|WHITE/ black         |+  |radio                       |
| RADIO ILLUMINATE|GREEN / WHITE         |+  |radio                       |
|       LF SPEAKER|wht/blu - blk/blu   |   |radio                       |
|       RF SPEAKER|wht/red - blk/red   |   |radio                       |
|       LR SPEAKER|yel/blu - gry/blu   |   |radio                       |
|       RR SPEAKER|yel/red - gry/red   |   |radio                       |
Notes:
NOTE:  This vehicle is equipped with an immobilizer.  Use DEI part number 555U to bypass during remote start operation.  *1 Located in a black 32 pin plug.  *2 These are the door key cylinder wires. Meter the wires while turning the key in the drivers door. Unlock requires a double pulse. On vehicles without the factory alarm use purple for lock and lt. GREEN/ red for unlock, these are the door lock switch wires.  *3 In the plug on the upper right side of the fuse box under the driver side dash.  *4 Go to the test connector inside the fusebox under the hood, it is a T shaped plug. Tach is the terminal on the top left of the T, the wire under the terminal is white or WHITE/ red.    *5 Located in a large white 38 pin plug behind the radio.  *6 To disarm without unlocking, use a single pulse on the unlock wire.  *7 Located in a white 43 pin plug.  *8 Located in a black 19 pin plug on the back of the fuse box under the driver side dash.  *9 Also found in a black 20 pin plug on the front of the fuse box under the driver side dash.
1994 Corolla Dx
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|       POWER LOCK|blue/black          |-  |passenger kick              |
|     POWER UNLOCK|blue/red *1         |-  |passenger kick              |
| PARKING LIGHTS +|green               |   |dimmer switch or kick       |
| PARKING LIGHTS -|lt. green or white  |   |steering column             |
|       HEADLIGHTS|RED / white           |-  |steering column             |
|     DOOR TRIGGER|RED / white or black*2|-  |plug at top of fusebox      |
|  TRUNK/HATCH PIN|RED / white *3        |-  |light or pin in trunk       |
|         HOOD PIN|red                 |-  |anti-theft ECU *4           |
|       TACHOMETER|black               |   |check connector             |
|      SPEED SENSE|RED / yellow          |4  |center console 22 pin plug  |
|       BRAKE WIRE|GREEN / WHITE         |+  |plug in fusebox             |
|     HORN TRIGGER|GREEN/ red           |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|yellow - green      |A  |in drivers door             |
|  RF WINDOW UP/DN|grn/red - blu/wht   |A  |in drivers door or DKP      |
|  LR WINDOW UP/DN|RED / grn - blu/blk   |A  |in drivers door or DKP      |
|  RR WINDOW UP/DN|RED / blk - yellow    |A  |in drivers door or DKP      |
Notes:
*1 GREEN / WHITE on models with factory alarm.  *2 Use the Black in a 2 pin connector at the top of the fusebox on versions without a sunroof.  On cars with a sunroof use the RED / white in a 4 or 6 pin connector in the same location.  When adding dome light supervision use the door trigger wire and relay isolate to keep ground from entering the fusebox side of the wire or unlock will not function properly.  *3 On the wagon version the rear door is tied in with the door trigger wire.  *4 The anti-theft ECU is located high in the drivers side kick panel.
Is up to installer to test all wires whenever possible with a DMM
Luis
Sound Waves
Posted By: sfowler
Date Posted: February 05, 2003 at 8:04 AM
You da man!
-Steve
Posted By: BNLUIS
Date Posted: February 05, 2003 at 9:19 PM
No problem,  happy to help. posted_image
Luis
Sound Waves
