dear sir can u submit a complete schematic diagram for the electric circuit of kia rio 2003
best regards,,,
Here is the information for the 2002 Rio which should be the same as the 2003's:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|blk/blu & grn/red |+ |ignition harness |
| STARTER|blue |+ |ignition harness |
| IGNITION|blue/red |+ |ignition harness |
| SECOND IGNITION|blue/black |+ |ignition harness |
| ACCESSORY|RED / blue |+ |ignition harness |
| PARKING LIGHTS +|RED / blu or wht/blu | |driver kickpanel,22 pin plug|
| PARKING LIGHTS -|green | |headlight switch |
| HEADLIGHTS|blue |- |headlight switch |
| DOOR TRIGGER|GREEN/ red |- |driver kickpanel,20 pin plug|
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|white |- |driver kickpanel,16 pin plug|
| TACHOMETER|BROWN / red | |ECM or diag plug *1 |
| SPEED SENSE|GREEN/ orange | |driver kickpanel,22 pin plug|
| BRAKE WIRE|RED / black |+ |brake pedal switch |
| HORN TRIGGER|lt. GREEN/ red |- |steering column |
| WIPERS|green(L), RED / wht(H)|+ |steering column |
| RADIO 12V|yellow/blue |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|BROWN / red |+ |radio |
| RADIO ILLUMINATE|blue/black |+ |radio |
| LF SPEAKER|wht/red - wht/grn | |radio |
| RF SPEAKER|yel/red - yel/blu | |radio |
| LR SPEAKER|RED / grn - RED / blk | |radio |
| RR SPEAKER|lt grn/red-lt grn/ye| |radio |
Notes:
*1 The ECM is in the driver kick panel. The tach wire is in pin 31 in the 52 pin plug. Can also find the tach wire in the diagnostic plug behind the driver side headlight.
