2005 Audi A6 Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91977
Printed Date: May 02, 2024 at 1:06 AM
Topic: 2005 Audi A6 Alarm/Remote Start Wiring
Posted By: tooler
Subject: 2005 Audi A6 Alarm/Remote Start Wiring
Date Posted: March 22, 2007 at 6:08 AM
I am looking for wiring connections to install a remote start for a 2005 Audi A6. Can anyone assist me?
Posted By: Twelvoltz
Date Posted: March 22, 2007 at 7:19 AM
Here is what Audiovox lists:
Security
WIRE COLOR POLARITY LOCATION
Battery RED / WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLUE (+) IGNITION SWITCH HARNESS
Starter 1 RED / BLACK (+) IGNITION SWITCH HARNESS
All Door Trigger RED / YELLOW (-) IN HARNESS IN DRIVERS KICKPANEL
Trunk Trigger WHITE/ YELLOW (-) IN HARNESS FROM TRUNK
Parking Lights GRAY/WHITE (+) AT VEHICLE LIGHT SWITCH
Remote Start
Ignition 2 VIOLET (+) IGNITION SWITCH HARNESS
Accessory 1 YELLOW/BLACK (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Tachometer GRAY/GREEN (AC) AT IGNITION COIL
Speed Sense WHITE/ BLUE (AC) RADIO HARNESS
Brake Lights RED / BLACK (+) AT SWITCH ABOVE BRAKE PEDAL
Doorlocks/Windows
Power Unlock BROWN / YELLOW (-) IN HARNESS IN DRIVERS KICKPANEL
PowerLock GREEN/ BLUE (-) IN HARNESS IN DRIVERS KICKPANEL
Always verify any connection with a DMM prior to interfacing with the wire.
------------- Installer, IT support, and FFL. I need less hobbies.
