2007 gmc sierra new body style, alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92759
Printed Date: April 27, 2024 at 1:33 PM
Topic: 2007 gmc sierra new body style, alarm
Posted By: underground
Subject: 2007 gmc sierra new body style, alarm
Date Posted: April 09, 2007 at 7:26 PM
Anyone have the alarm info for a 2007 GMC Sierra Crew Cab? I wanted to hook up a keyless entry system but figured it might be better just to do a full alarm. Any help would be great!
Posted By: Velocity Motors
Date Posted: April 09, 2007 at 10:31 PM
GMC 2007 Sierra 4DR Pickup (Remote Start / Security / GPS)
Remote start / security / GPS Wire/Function | Colour | Location/Description | Polarity | PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES | 12 VOLTS | RED / white (x3) | In black plug on BCM to left of steering column | + | IGNITION | Pink | Ignition switch harness | + | ACCESSORY | Yellow | Ignition switch harness | + | STARTER | Pink/black (1290-ohms) | Ignition switch harness | mux | | | Follow the provided diagram for correct wiring of the starter wire for remote start. |
| TACH SIGNAL | Lt.green | In large harness on lower driver's side of engine | AC | LOCK | Data interface module required | | | UNLOCK | Data interface module required | | | DOORPIN | Gray/black & Tan/white | In each front door at switch assembly | - | HOODPIN | Pink/black | In black plug on BCM to left of steering column | - | TRUNK PIN | Pink/black | In pink plug on BCM to left of steering column | - | TRUNK RELEASE | Pink | In pink plug on BCM to left of steering column | - | | | This is the rear window release |
| FACTORY DISARM | Lt.green | On brown plug at switch assembly in driver's door | - | BRAKESWITCH | Lt.blue | In pink plug on BCM to left of steering column | + | | | Must test with ignition on. |
| PARKLIGHTS (-) | Dk.blue | In brown plug on BCM to left of steering column | - | HAND BRAKE | Lt.blue | In brown plug on BCM to left of steering column | | HORN | Tan | In brown plug on BCM to left of steering column | - |
------------- Jeff
Date Posted: April 10, 2007 at 6:55 PM
Thanks Jeff, once again you help save the day!
Date Posted: April 12, 2007 at 11:36 PM
Hey Jeff? What is a good keyless entry system to install on my 2007 GMC, and what all do I need to make it work? Thanks in advance!
Date Posted: April 17, 2007 at 5:37 PM
Did you only want keyless entry ? No remote start or alarm ?
------------- Jeff
Date Posted: April 17, 2007 at 10:59 PM
Keyless entry is all I really need, how much harder would an alarm be?
Date Posted: April 29, 2007 at 10:07 AM
Compustar system are really good and they are the main brand that I deal with. The installation for the new GM's are really easy seeing that everything is controlled through databus wires. Just get a module to control everything and your set.
------------- Jeff
Date Posted: May 03, 2007 at 4:59 PM
How much can I get everything from you for? Also maybe a step by step instruction guide. How much?
Date Posted: May 09, 2007 at 10:37 PM
So how much will everything run me?
