Does anyone have the info. on a 2002 Ford Focus ZX3? If so can you please let me have it. Also it has a blinking light on the center of the dash, what will I do with this one if I use a different one for the alarm? Any help will be usefull. Thanks in advance!
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness |
| STARTER|gray/black |+ |ignition harness |
| IGNITION|GREEN/ YELLOW |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|BLACK/ red |- |drivers kick panel |
| POWER UNLOCK|BLACK / YELLOW |- |drivers kick panel |
| LOCK MOTOR|yellow/black | |drivers kick panel |
| UNLOCK MOTOR|WHITE/ black | |drivers kick panel |
| DISARM DEFEAT|WHITE/ black | |passengers kick panel |
| PARKING LIGHTS +|orange / YELLOW | |headlight switch |
| PARKING LIGHTS -| | | |
| HEADLIGHTS|grn/blu(L),grn/yel(H|+ |steering column *3 |
| DOOR TRIGGER|BLACK/ blue |- |low in drivers kick panel |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|BLACK/ white |- |trunk light |
| HOOD PIN|BLACK / YELLOW *4 |- |keyless module *1 |
|TRNK/HTCH RELEASE|BLACK / YELLOW |- |switch or keyless module *1 |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| DISARM NO UNLOCK| | | |
| TACHOMETER|BLACK/ green | |ignition coil |
| SPEED SENSE|WHITE/ green | |radio |
| BRAKE WIRE|lt. GREEN/ red |+ |brake switch *2 |
| HORN TRIGGER|BLACK/ blue |- |steering column |
| WIPERS|WHITE/ green |+ |steering column |
| LF WINDOW UP/DN|yellow - white |A |in drivers door at motor |
| RF WINDOW UP/DN|yel/pur - wht/pur |A |drivers switch or kick panel|
| LR WINDOW UP/DN|yel/blu - wht/blu |A |drivers switch or kick panel|
| RR WINDOW UP/DN|yellow - white |A |drivers switch or kick panel|
| SUN RF OPN/CLOSE| | | |
| SUN ROOF LIMIT| | | |
| RADIO 12V|ORANGE / black (thick)|+ |radio |
| RADIO GROUND|blk/yel & blk/grn |- |radio |
| RADIO SWITCH|YELLOW /GREEN |+ |radio |
| RADIO ILLUMINATE|ORANGE / black (thin) |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|wht/blk - gry/blk | |radio |
| RF SPEAKER|wht/red - gry/red | |radio |
| LR SPEAKER|wht/pur - gry/wht | |radio |
| RR SPEAKER|white - gray | |radio |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555S to bypass. *1 Keyless module is behind the glove box to the right. *2 To meter the brake wire, must turn ignition on. *3 Low beam at the headlight switch is GREEN/ red. *4 Only if equipped with factory alarm.
