07 expedition wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94350
Printed Date: May 03, 2024 at 9:34 AM
Topic: 07 expedition wiring diagram
Posted By: acrbill
Subject: 07 expedition wiring diagram
Date Posted: May 29, 2007 at 4:45 PM
Could someone help me find the wiring diagram for a 2007 Expedition.
Posted By: mikvot
Date Posted: May 29, 2007 at 7:21 PM
12volts blue/red (x2)(common 20A) + ignition harness Starter blue/white + ignition harness Second Starter N/A Ignition WHITE/ orange + ignition harness Second Ignition N/A Third Ignition N/A Accessory BROWN / yellow + ignition harness Second Accessory PURPLE / green + ignition harness Keysense blue/gray + ign harn or SJB, conn. G, pin 35 Power Lock WHITE/ brown - driver kick or SJB, conn. D, pin 17 Power Unlock blue/brown - driver kick or SJB, conn. D, pin 4 Lock Motor gray/brown 5wi driver kick or SJB, conn. E, pin 6 Unlock Motor blue/green 5wi driver kick or SJB, conn. E, pin 28 Parking Lights+ PURPLE / white + pass kick or SJB, conn. E, pin 20 Parking Lights- blue/gray - switch or SJB, conn. G, pin 31 Hazards GREEN/ orange - switch or SJB, conn. G, pin 48 Turn Signal(L) blue/green (F), gray/brown (R) + SJB, conn B, pin 21; conn E, pin 25 Turn Signal(R) yellow/pur (F), PURPLE / org (R) + SJB, conn B, pin 23; conn E, pin 26 Reverse Light GREEN/ brown + passenger kick, harness to rear Door Trigger see notes - each kick or SJB, conn. D Dome Supervision gray/purple + driver kick or SJB, conn. F, pin 9 Trunk/Hatch Pin gray/orange - pass kick or SJB, conn. D, pin 16 Hood Pin N/A Trunk/Hatch Release brown (hatch), brn/yel (glass) - SJB, conn. D, pins 7 and 20 Power Sliding Door N/A Factory Alarm Arm N/A Factory Alarm Disarm N/A Disarm No Unlock N/A Tachometer NOT GREEN/ purple or PURPLE / grn ac any ignition coil or fuel injector Wait to start N/A Brake Wire yellow/gray + switch or SJB, conn. G, pin 40 Parking Brake PURPLE / brown - switch or SJB, conn. D, pin 1 Horn Trigger yellow/red - switch or SJB, conn. G, pin 41 Memory Seat 1 PURPLE / white - switch or DSM, conn. D, pin 9 Memory Seat 2 yellow - switch or DSM, conn. C, pin 11 Memory Seat 3 N/A -
Posted By: acrbill
Date Posted: May 29, 2007 at 7:28 PM
thanks pal!
Posted By: trpltongue
Date Posted: May 31, 2007 at 1:26 PM
Do you happen to have the info on the radio pinouts, including the DVD plug? Thanks, Russell
