05 Chrysler PT Cruiser Convertible Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95163
Printed Date: May 02, 2024 at 11:07 AM
Topic: 05 Chrysler PT Cruiser Convertible Alarm/Remote Start Wiring
Posted By: guinness2
Subject: 05 Chrysler PT Cruiser Convertible Alarm/Remote Start Wiring
Date Posted: June 27, 2007 at 2:11 PM
Can anyone help me with a complete security,remote start wiring diagram for this car?
Posted By: KarTuneMan
Date Posted: June 27, 2007 at 2:58 PM
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES | 12 VOLTS | Pink/black | Ignition switch harness | + | IGNITION | Blue | Ignition switch harness | + | ACCESSORY | BLACK/ orange | Ignition switch harness | + | STARTER | Yellow | Ignition switch harness | + | KEY SENSE | Lt.blue | Ignition harness | - | TACH SIGNAL | BLACK/ gray | At PCM under hood | AC | | | The PCM is located on the driver's side firewall under the hood. The BLACK/ GRAY is found in the gray connector. |
| LOCK | WHITE/ green | Above driver's kickpanel | - | | | This vehicle uses multiplexing where a single wire performs all lock and security functions, resistors are required. See the DOORLOCKS diagram for wiring details. |
| UNLOCK | WHITE/ green | Above driver's kickpanel | - | | | This vehicle uses multiplexing where a single wire performs all lock and security functions, resistors are required. See the DOORLOCKS diagram for wiring details. |
| DOORPIN | SEE NOTES | White connector in driver's kickpanel | - | | | TAN (driver's door), BLUE/ORANGE or BLUE (all other doors). Both wires are found in a WHITE connector in the driver's kickpanel. |
| TRUNK PIN | Tan/black | White connector in driver's kickpanel | - | FACTORY ARM | WHITE/ green | Above driver's kickpanel | - | | | This vehicle uses multiplexing where a single wire performs all lock and security functions, resistors are required. See the DOORLOCKS diagram for wiring details. |
| FACTORY DISARM | WHITE/ green | Above driver's kickpanel | - | | | This vehicle uses multiplexing where a single wire performs all lock and security functions, resistors are required. See the DOORLOCKS diagram for wiring details. |
| BRAKESWITCH | WHITE/ tan | In driver's kickpanel | + | | | It is recommended that you use the wire found in the driver's kickpanel and not the one at the brakeswitch itself. |
| PARKLIGHTS | BLACK / YELLOW | At steering column | + | HAND BRAKE | Gray/black | Front right side of shifter | - | HORN | BLACK/ red | At steering column | - |
Date Posted: June 28, 2007 at 6:44 PM
Thank you for your quick response .
