2008 Ford F-450 Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95781
Printed Date: April 27, 2024 at 1:09 PM
Topic: 2008 Ford F-450 Alarm/Remote Start Wiring
Posted By: marcosbmonzon
Subject: 2008 Ford F-450 Alarm/Remote Start Wiring
Date Posted: July 20, 2007 at 4:14 PM
does anyone know wiring diagram for a 2008 ford f450 with a 5.4 diesel
Posted By: mikvot
Date Posted: July 20, 2007 at 5:15 PM
12volts blue/red (x2)(common 20A) + ignition harness Starter blue/white + ignition harness Second Starter N/A Ignition WHITE/ orange + ignition harness Second Ignition N/A Third Ignition N/A Accessory BROWN / yellow + ignition harness Second Accessory PURPLE / green + ignition harness Keysense blue/lt. gray + ignition harness Power Lock blue/lt. green - driver kick, door harness Power Unlock yellow/purple - driver kick, door harness Lock Motor Unlock Motor PURPLE / gray 5wi driver kick, door harness Parking Lights+ PURPLE / white + SJB, conn. D, pin 20 Parking Lights- gray - headlight switch Hazards Turn Signal(L) Turn Signal(R) Reverse Light GREEN/ brown + harness to rear Door Trigger see notes - each kick or SJB, conn. C Dome Supervision yellow/gray + SJB, conn. A Trunk/Hatch Pin Hood Pin Trunk/Hatch Release Power Sliding Door Factory Alarm Arm Factory Alarm Disarm Disarm No Unlock Tachometer blue/white ac PCM or Customer Access Point Wait to start see DirectFax document 1091 Brake Wire PURPLE / white + brake pedal switch Parking Brake WHITE/ purple - switch or SJB, conn. C, pin 1 Horn Trigger yellow/red - horn switch Memory Seat 1 PURPLE / white - driver kick, door harness Memory Seat 2 yellow - driver kick, door harness Memory Seat 3 -
Date Posted: July 21, 2007 at 12:51 PM
thanks alot for your help
Posted By: mikvot
Date Posted: July 21, 2007 at 8:07 PM
No prob....for your info, the the sjb is in the passenger kick panel, but i've done quite a few alarms on these, and i catch the locks and park lights(+) in the drivers kick, and the dome light (delayed) can be found in the drivers door sill, behind drivers seat where harness t's behind the seat. I've never gone to pass. side for anything.
