2004 Acura TL Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96587
Printed Date: April 24, 2026 at 12:02 AM
Topic: 2004 Acura TL Alarm/Remote Start Wiring
Posted By: chatemate
Subject: 2004 Acura TL Alarm/Remote Start Wiring
Date Posted: August 22, 2007 at 8:48 PM
12voltswhite (50A) + ignition harness
StarterBLACK/ white + ignition harness
Second StarterN/A
IgnitionBLACK / YELLOW + ignition harness
Second IgnitionN/A
Third IgnitionN/A
AccessoryBLACK/ red + ignition harness
Second AccessoryWHITE/ red + ignition harness
KeysenseRED / white - ignition harness
Power Lockpink/black - green plug, left side of fuse box
Notes: These wires will meter when using the passenger door lock switch.
Power Unlockpink/blue - green plug, left side of fuse box
Lock Motoryellow/black 5wi green plug, front of fuse box
Unlock MotorYELLOW /GREEN 5wi green plug, front of fuse box
Parking Lights+RED / black + large white plug, top of fuse box
Parking Lights-RED / black - headlight switch in column cover
HazardsGREEN/ red + large white plug, top of fuse box
Turn Signal(L)RED / blue + large white plug, top of fuse box
Turn Signal(R)white + large white plug, top of fuse box
Reverse Lightgreen + driver kick, harness to rear
Door Triggersee notes - rear of fuse box
Notes: The LF door is green in a 16 pin plug, pin 15. The RF door is lt. GREEN/ red in a 14 pin plug, pin 12. The LR door is GREEN/ YELLOW in a 16 pin plug, pin 14. The RR door is GREEN / WHITE in a 14 pin plug, pin 13. Use all four wires and diode isolate each.
Dome SupervisionGREEN/ red - green 5 pin plug, rear of fuse box
Trunk/Hatch Pinblue / YELLOW - green plug, left side of fuse box
Hood Pinyellow/red or GREEN/ black - hood pin switch in latch
Trunk/Hatch ReleaseYELLOW /GREEN or blue/black + driver kick, harness to rear
Power Sliding DoorN/A
Factory Alarm Armblue/white to WHITE/ red - driver door module in door
Factory Alarm DisarmBLACK/ red to white - driver door module in door
Disarm No Unlocksee factory alarm disarm
TachometerNOT yellow/black ac any fuel injector
Wait to startN/A
Brake WireWHITE/ black + brake pedal switch
Parking BrakeGREEN/ orange - large white plug, top of fuse box
Horn TriggerGREEN/ YELLOW - horn switch
Memory Seat 1blue / YELLOW - driver door module in door
Memory Seat 2RED / yellow - driver door module in door
Memory Seat 3N/A -
TEAL-DEAL
