2002 kia sportage wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97239
Printed Date: April 24, 2024 at 8:57 PM
Topic: 2002 kia sportage wiring diagram
Posted By: sinfonian
Subject: 2002 kia sportage wiring diagram
Date Posted: September 18, 2007 at 9:23 PM
Could anyone please post a wiring diagram for a 2002 Kia Sportage. I am installing a keyless entry/alarm system. Thanks!
Posted By: kola7126
Date Posted: September 24, 2007 at 9:03 AM
12 VOLT CONSTANT | WHITE (+) and RED (+) | IGNITION SWITCH HARNESS | | STARTER | GREEN (+) | IGNITION SWITCH HARNESS | | STARTER 2 | N/A | | | IGNITION 1 | BLUE (+) | IGNITION SWITCH HARNESS | | IGNITION 2 | N/A | | | IGNITION 3 | N/A | | | ACCESSORY /HEATER BLOWER 1 | ORANGE (+) | IGNITION SWITCH HARNESS | | ACCESSORY /HEATER BLOWER 2 | PINK (+) | IGNITION SWITCH HARNESS | | KEYSENSE | N/A | | | PARKING LIGHTS ( - ) | BROWN (-) | @ HEADLIGHT SWITCH | | PARKING LIGHTS ( + ) | GREEN (+) and GREEN (+) Use both, See NOTE *1 | @ HEADLIGHT SWITCH, See DIAGRAM | 14301_SPORTAGE_DUAL PARKING LIGHT DIAGRAM.pdf | POWER LOCK | GREEN (TYPE B) | IN DRIVERS KICK PANEL | | POWER UNLOCK | BLUE (TYPE B) | IN DRIVERS KICK PANEL | | LOCK MOTOR WIRE | RED (+) | IN DRIVERS KICK, at DOOR HARNESS | | DOOR TRIGGER | ORANGE (-) | IN DRIVERS KICK PANEL | | DOMELIGHT SUPERVISION | BROWN (-), Requires Part #775 Relay | @ ETACM Module, 26-pin plug, pin 1, See NOTE *2 | | TRUNK RELEASE | N/A | | | SLIDING POWER DOOR | N/A | | | HORN | BLUE (-) | @ HORN SWITCH | | TACH | BLUE | @ ECM, See NOTE *3 | | WAIT TO START LIGHT | N/A | | | BRAKE | RED (+) | @ SWITCH ABOVE BRAKE PEDAL | | FACTORY ALARM DISARM | N/A | | | ANTI-THEFT | TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY | TRANSPONDER @ IGNITION SWITCH TUMBLER | |
NOTES | NOTE *1 this vehicle has (2) PARKING LIGHT wires and will require (2) extra Relays part #775, to connect, See DIAGRAM
NOTE *2 the ETACM (Electronic Timing/Alarm Control Module) is located in the CENTER CONSOLE, behind the RADIO and HEATER CONTROL opening.
NOTE *3 the ECM (Electronic Control Module) is located on the DRIVERS SIDE FIREWALL, under the HOOD, on the 2.0L, the TACH wire is in PIN 66, on the 2.7L, the TACH is in the 40-pin plug, pin 17.
