2007 Scion tC Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97519
Printed Date: May 01, 2024 at 10:42 PM
Topic: 2007 Scion tC Alarm/Remote Start Wiring
Posted By: Johnnynguyen20
Subject: 2007 Scion tC Alarm/Remote Start Wiring
Date Posted: September 28, 2007 at 8:40 PM
hello, is there anyone have the wiring diagram for this 2007 Scion TC? is this same as the 2006 Scion TC? help please
------------- Johnnynguyen
Posted By: KarTuneMan
Date Posted: September 29, 2007 at 12:04 AM
12 VOLTS | Red | Ignition switch harness | + | IGNITION | Blue | Ignition switch harness | + | IGNITION 2 | Yellow | Ignition switch harness | + | ACCESSORY | Gray | Ignition switch harness | + | STARTER | Black | Ignition switch harness | + | STARTER 2 | Green | Ignition switch harness | + | TACH SIGNAL | Black | At diagnostic plug under dash | AC | LOCK | Green | On 20-pin plug in driver's kickpanel | - | UNLOCK | Violet | On 20-pin plug in driver's kickpanel | - | DOORPIN | SEE NOTES | | | | | Driver's door is ORANGE and passenger door is BLUE. Both wires are found on the left side of the fusebox. |
| TRUNK PIN | Purple | On top of fusepanel | - | TRUNK RELEASE | Orange | On 12-pin plug in driver's kickpanel | - | FACTORY ARM | Arms with lock wire | | | FACTORY DISARM | Disarms with unlock | | | BRAKESWITCH | Blue | At switch above brake pedal | + | PARKLIGHTS | Brown | On top of fusepanel | + | HAND BRAKE | Black | At switch on handbrake lever | - | HORN | White | At steering column | - | VSS WIRE | Violet | At ECM (behind glove box) | AC |
