07 dodge dakota alarm wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97593
Printed Date: May 12, 2024 at 5:16 PM
Topic: 07 dodge dakota alarm wiring
Posted By: benojeda
Subject: 07 dodge dakota alarm wiring
Date Posted: October 01, 2007 at 6:29 PM
really need the wiring diagram for my truck 2007 dodge dakota crew cab 3.7 liter  thanks
life is good when you know everything so i need alot of everything to make life good :)
Posted By: ceasar326
Date Posted: October 03, 2007 at 9:48 PM
12voltslt. blue/red (20A) + ignition harness
Starteryel/gry (not for remote start) + driver fender, gray 1 pin plug
Notes: Also found at the IPM, brown 40 pin plug, pin 9.
The IPM (Integrated Power Module) is the fuse/relay box on the driver side fender.
Second StarterPURPLE / brown - ignition harness
Notes: Starter is negative trigger thru a 180 ohm resistor. Refer to DirectFax document 1084 for wiring information.
Ignitionpink/gray + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessorysame as second starter wire
Notes: Accessory is negative trigger thru a 560 ohm resistor. Refer to DirectFax document 1084 for wiring information.
Second AccessoryN/A
Keysensesame as second starter wire
Notes: Key sense is negative trigger thru a 8500 ohm resistor.
Power LockPURPLE / dk. green - DKP or cluster, gry 16P plug, pin 3
Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays.
Power Unlocksame as power lock wire
Lock Motorlt. green 5wi DKP or cluster, gry 26P plug, pin 15
Unlock Motortan/lt. green 5wi DKP or cluster, gry 26P plug, pin 12
Parking Lights+pink/red (L), WHITE/ orange (R) + IPM, black 20 pin plug, pins 15, 17
Notes: The IPM (Integrated Power Module) is the fuse/relay box on the driver side fender.
The rear taillight wires run from this location down into a harness that follows the frame rail to the rear of the vehicle.
Parking Lights-pink/red - sw or cluster, gry 16P plug, pin 5
Notes: Parking lights are negative trigger thru a 1130 ohm resistor. MUST use a relay.
HazardsWHITE/ orange - sw or cluster, gry 16P plug, pin 8
Notes: The hazard lights are negative trigger thru a 120 ohm resistor. MUST use a relay.
Turn Signal(L)wht/lt. grn(F), wht/dk. grn(R) + FCM, blk 12P plug; IPM, brn 40P plug
Notes: The FCM (Front Control Module) is attached to the IPM (Integrated Power Module), which is the fuse/relay box on the driver side fender.
Turn Signal(R)WHITE/ tan (F), WHITE/ orange(R) + FCM, blk 12P plug; IPM, brn 40P plug
Reverse LightWHITE/ lt. green + IPM, brown 40 pin plug, pin 27
Door Triggersee notes - each kick or cluster
Notes: The LF door is purple in the gray 26 pin plug, pin 6. The RF door is PURPLE / white in the white plug, pin 23. The LR door is PURPLE / gray in the gray 26 pin plug, pin 8. The RR door is purple / YELLOW in the white plug, pin 22. Use all four wires and diode isolate each.
Dome Supervisionyellow/orange + cluster, white plug, pin 11
Notes: Also found in the passenger A pillar.
Trunk/Hatch PinN/A
Hood PinPURPLE / lt. blue - pin sw or IPM, wht 20P plug, pin 16
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armarms on lock with door open
Factory Alarm Disarmfactory remote only
Disarm No Unlockwith ign, keysense, Sentry Key
TachometerNOT red ac any ignition coil or fuel injector
Wait to startN/A
Brake WireWHITE/ lt. blue + brake pedal switch
Parking Brakedk. GREEN / WHITE - sw or cluster, gry 26P plug, pin 3
Horn Triggerdk. GREEN/ purple - sw or cluster, gry 26P plug, pin 10
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
posted_image
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Sentry Key
Part #: PKU-CH2X
Alternate Part1 #: 556CW
Alternate Part2 #: 556UW
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Standard on the SLT and Laramie models.
Door Lock Interface
Required:
No
Type:
Data Bus
Part #: XK03
Alternate Part1 #: 456LW
Notes:
Combo Interface
Required:
No
Type:
Data Bus
Part #: XK532
Alternate Part1 #: IOM-Chrysler-7
Notes: When using the combo module it is not necessary to use doc 1084. That part takes care of 2nd starter and accessory, locks, and bypass.
Posted By: jatkinson07
Date Posted: October 04, 2007 at 12:57 PM
Anyone know location and color for the vehicle speed sense wire for a 2007 Dodge Dakota Quad Cab 4.7L?
