Print Page | Close Window |
2005 Nissan Altima Alarm/Remote Start/Stereo WiringPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98897 Printed Date: May 31, 2024 at 7:00 PM Topic: 2005 Nissan Altima Alarm/Remote Start/Stereo Wiring Posted By: aggieman2002 Subject: 2005 Nissan Altima Alarm/Remote Start/Stereo Wiring Date Posted: November 11, 2007 at 9:34 PM do anyone have the wiring information for 05 altima. Need to install an alarm.
Replies: Posted By: Twelvoltz Date Posted: November 12, 2007 at 9:03 AM Audiovox Lists:
#506757: 2005 NISSAN ALTIMA 4DR SEDAN WITH 2.5L ENGINE AND BOSE® AUDIO SYSTEM Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery YELLOW /GREEN (+) RADIO HARNESS Accesory PURPLE (+) RADIO HARNESS Ground CHASSIS (-) CHASSIS GROUND THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS. Illumination RED / BLUE (+) RADIO HARNESS Dimmer RED / YELLOW (+) RADIO HARNESS Power Antenna GREEN (+) RADIO HARNESS Amp Turn On GREEN / WHITE (+) RADIO HARNESS LF Speaker (+) BLUE/WHITE LF Speaker (-) BLUE/RED RF Speaker (+) WHITE/ BLACK RF Speaker (-) BLUE/BLACK LR Speaker (+) GREEN/ YELLOW LR Speaker (-) BLACK / YELLOW RR Speaker (+) BLUE RR Speaker (-) RED Amp Location UNDER REAR DECK IN TRUNK Steering Cntrls YES Speed Cntrl YES Radio Security YES Security WIRE COLOR POLARITY LOCATION Battery GREEN (+) AT IGNITION HARNESS Ignition 1 BLACK/ RED (+) AT IGNITION HARNESS Starter 1 BLACK/ RED (+) AT IGNITION HARNESS All Door Trigger USE LATCH WIRES (-) DIODE ISOLATE PIN #32 Domelight Super RED (-) BCM PIN 63 PIN #32 LF Latch LIGHT BLUE (-) BCM PIN 47 WHEN INSTALLING A REMOTE START IN AN ALTIMA WITH AUTO-HEALIGHTS, YOU MUST PULSE THIS WIRE GROUND WHEN THE REMOTE START SHUTS DOWN TO KEEP THE HEADLIGHTS FROM STAYING ON. RF Latch PINK/BLUE (-) BCM PIN 12 PIN #10 LR Latch RED / BLACK (-) BCM PIN 48 PIN #11 - BOTH REAR DOORS ARE MONITORED BY THIS WIRE. RR Latch RED / WHITE (-) BCM PIN 13 PIN #11 - BOTH REAR DOORS ARE MONITORED BY THIS WIRE. Trunk Trigger PURPLE / WHITE (-) BCM PIN 42 PIN #18 Hood Trigger YELLOW/BLACK (-) AT POWER DISTRIBUTION CENTER UNDER HOOD PIN #51 Alarm Disarm WHITE/ BLUE (-) IN THE DRIVERS DOOR AT DOOR MODULE PIN 4 SINGLE PULSE WILL DISARM THE ALARM AND A DOUBLE PULSE WILL UNLOCK THE DOORS. Alarm Arm PINK/BLUE (-) IN THE DRIVERS DOOR AT DOOR MODULE PIN 5 PIN #59 - THIS WIRE RESTS AT +5V, USE A RELAY TO PULSE THIS WIRE TO PREVENT A +12V SIGNAL FROM BEING APPLIED BY SOME ALARM OR KEYLESS ENTRY SYSTEMS. Parking Lights RED / BLUE (+) DRIVERS SILL PLATE ALSO AT DIMMER SWITCH LEFT SIDE OF STEERING COLIMN ON DASH. Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo BLUE (LEFT), RED / YELLOW (RIGHT) (+) GRAY 16 PIN CONNECTOR AT IPDM E/R PIN #24 & #22 - USE BOTH WIRES AND DIODE ISOLATE THEM. Headlights-Hi BLUE/WHITE & GREEN (+) AT POWER DISTRIBUTION CENTER UNDER HOOD PIN #21 & #27 - USE BOTH WIRES AND DIODE ISOLATE THEM. LF Pk Lt Bulb RED / BLUE (+) AT FRONT LEFT PARKING LIGHT RF Pk Lt Bulb RED / BLUE (+) AT FRONT RIGHT PARKING LIGHT LR Pk Lt Bulb RED / BLUE (+) AT REAR LEFT PARKING LIGHT RR Pk Lt Bulb RED / BLUE (+) AT REAR RIGHT PARKING LIGHT All Hazrd Lights GREEN/ RED (-) BCM PIN 29 PIN #61 LF Hazrd Bulb GREEN/ BLACK (+) AT FRONT LEFT DIRECTIONAL LIGHT WILL ALSO BE FOUND AT BCM MODULE BEHIND LEFT SIDE OF DASH NEAR FUSE PANEL - PIN #22 RF Hazrd Bulb GREEN/ YELLOW (+) AT FRONT RIGHT DIRECTIONAL LIGHT WILL ALSO BE FOUND AT BCM MODULE BEHIND LEFT SIDE OF DASH NEAR FUSE PANEL - PIN #21 LR Hazrd Bulb GREEN/ BLACK (+) AT REAR LEFT DIRECTIONAL LIGHT WILL ALSO BE FOUND AT BCM MODULE BEHIND LEFT SIDE OF DASH NEAR FUSE PANEL - PIN #22 RR Hazrd Bulb GREEN/ YELLOW (+) AT REAR RIGHT DIRECTIONAL LIGHT WILL ALSO BE FOUND AT BCM MODULE BEHIND LEFT SIDE OF DASH NEAR FUSE PANEL - PIN #21 Wipers-Lo BLUE (+) GRAY 16 PIN CONNECTOR AT IPDM E/R PIN #31 Wipers-Hi BLUE/BLACK (+) GRAY 16 PIN CONNECTOR AT IPDM E/R PIN #30 Parking Brake GREEN (-) AT PARKING BRAKE SWITCH Trnk Release RED / BLACK (-) BCM PIN 30 MAY ALSO BE BLUE/RED Remote Start WIRE COLOR POLARITY LOCATION Battery GREEN (+) AT IGNITION HARNESS Ignition 1 BLACK/ RED (+) AT IGNITION HARNESS Ignition 2 BLACK/ RED (+) IGNITION SWITCH HARNESS Accessory 1 RED (+) AT IGNITION HARNESS Accessory 2 WHITE/ BLUE (+) AT IGNITION HARNESS Starter 1 BLACK/ RED (+) AT IGNITION HARNESS Starter 2 BLACK / YELLOW (+) AT IGNITION HARNESS Anti-Theft Type NISSAN NVIS® VEHICLE IMMOBILIZER Anti-Theft Descript TRANSPONDER Key Sense BLACK/ RED (-) AT IGNITION HARNESS ALSO AT BCM PIN 37 Neutral Safety GREEN/ RED (-) AT ECM MODULE BEHIND GLOVEBOX ABOVE PASSENGER FOOTWELL PIN #43 - WILL BE GREEN/ RED ON AUTOMATIC TRANSMISSION MODELS AND GREEN / WHITE ON MANUAL TRANSMISSION MODELS. Tachometer USE INJECTOR OR COIL (AC) USE UNCOMMON WIRE ON ANY COIL OR INJECTOR THE VEHICLE TACHOMETER SIGNAL IS SENT THROUGH A DATABUS LINE - YOU MUST USE A CRANKSHAFT OR CAMSHAFT POSITION SENSOR OR A FUEL INJECTOR SIGNAL WIRE. Crankshaft Sensor WHITE (AC) AT ECM MODULE BEHIND GLOVEBOX ABOVE PASSENGER FOOTWELL PIN #71 Camshaft Sensor WHITE (AC) AT ECM MODULE BEHIND GLOVEBOX ABOVE PASSENGER FOOTWELL PIN #62 Speed Sense PINK MAY ALSO BE BLACK. THIS IS ON THE MIDLINE AND BOSE RADIO VEHICLES ONLY. VEHICLES WITHOUT 5 SPEED AUTOMATIC TRANSMISSION CAN USE A BLUE / YELLOW BEHIND INSTRUMENT CLUSTER. Parking Lights RED / BLUE (+) DRIVERS SILL PLATE ALSO AT DIMMER SWITCH LEFT SIDE OF STEERING COLIMN ON DASH. Brake Lights RED / GREEN (+) AT BRAKE SWITCH Reverse Lights GREEN / WHITE (+) DRIVERS SILL PLATE Horn GREEN / WHITE (-) AT STEERING COLUMN HARNESS Anti Theft RX BLUE/RED (DATA) AT IMMOBILIZER CONTROL UNIT IN STEERING COLUMN Anti Theft TX WHITE/ BLUE (+) AT IMMOBILIZER CONTROL UNIT IN STEERING COLUMN Modules WIRE LOCATION Module 1 BCM IS LOCATED TO THE RIGHT OF THE FUSE BOX Module 2 IPDM E/R (INTELLIGENT POWER DISTRIBUTION MODULE ENGINE ROOM) IS UNDER HOOD BEHIND PASSENGERS HEADLIGHT. Doorlocks/Windows WIRE COLOR POLARITY LOCATION Power Unlock PINK (-) BCM PIN 46 THIS WIRE IS USED FOR VEHICLES WITH LEFT FRONT ANTI PINCH SYSTEM ONLY. ON VEHICLES WIYH BOTH FRONT WINDOW ANTI PINCH USE FACTORY ARM/DISARM WIRES FOR LOCK/UNLOCK. PowerLock BROWN (-) BCM PIN 45 TEST WITH THE KEY IN THE DRIVERS DOOR. THIS WIRE IS USED FOR VEHICLES WITH LEFT FRONT ANTI PINCH SYSTEM ONLY. ON VEHICLES WIYH BOTH FRONT WINDOW ANTI PINCH USE FACTORY ARM/DISARM WIRES FOR LOCK/UNLOCK. 2 Step Unlock GREEN / WHITE (+) AT BCM MODULE BEHIND LEFT SIDE OF DASH NEAR FUSE PANEL PIN #23 Driver Mtr Unlock GREEN/ RED (REV) BCM PIN 66 Driver Mtr Lock YELLOW/RED (REV) BCM PIN 65 Pas Mtr Unlock GREEN / WHITE (REV) BCM PIN 59 Pas Mtr Lock GREEN/ RED (+) AT MOTOR IN DOOR LF Window Up BLUE/RED (REV) AT DRIVERS WINDOW SWITCH IN DOOR LF Window Dn BLUE/WHITE (REV) AT DRIVERS WINDOW SWITCH IN DOOR RF Window Up GREEN (REV) DRIVERS KICK PANEL IF VEHICLE HAS AUTO UP/DOWN ON PASSENGERS FRONT WINDOW YOU MUST USE BLUE FOR UP AND GREEN/ BLACK FOR DOWN IN THE PASSENGERS DOOR. RF Window Dn YELLOW (REV) DRIVERS KICK PANEL IF VEHICLE HAS AUTO UP/DOWN ON PASSENGERS FRONT WINDOW YOU MUST USE BLUE FOR UP AND GREEN/ BLACK FOR DOWN IN THE PASSENGERS DOOR. LR Window Up PURPLE (REV) DRIVERS KICK PANEL LR Window Dn BLUE (REV) DRIVERS KICK PANEL RR Window Up RED / YELLOW (REV) DRIVERS KICK PANEL RR Window Dn YELLOW/BLACK (REV) DRIVERS KICK PANEL Sunroof Open ORANGE (+) AT SUNROOF SWITCH THIS WIRE WILL EITHER CLOSE THE VENT POSITION OR SLIDE THE SUNROOF OPEN DEPENDING ON THE CURRENT STATE OF THE ROOF. Sunroof Close BLUE/RED (+) AT SUNROOF SWITCH TEST WITH THE KEY IN THE DRIVERS DOOR Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation. ------------- Installer, IT support, and FFL. I need less hobbies. |
