2007 honda odyssey nav info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99041
Printed Date: May 04, 2024 at 9:09 AM
Topic: 2007 honda odyssey nav info
Posted By: cschoen
Subject: 2007 honda odyssey nav info
Date Posted: November 15, 2007 at 4:25 PM
Hello All, I'm installing a AVIC D3 into a 2007 Odyssey and can't seem to find the wiring info for anything but the alarm. All help appreciated.
Posted By: BNLUIS
Date Posted: November 15, 2007 at 4:59 PM
what wire info you need? back lights,VSS wire?
------------- Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Posted By: cschoen
Date Posted: November 15, 2007 at 5:55 PM
Sorry, Speed signal and Reverse gear signal. Thanks
Posted By: BNLUIS
Date Posted: November 15, 2007 at 7:08 PM
Speed Sense | blue/white | | PCM, conn. A, pin 29 |
Reverse Light | green | + | dr kick or MICU, 14 pin plug, pin 11 |
------------- Luis
Sound Waves
Posted By: cschoen
Date Posted: November 15, 2007 at 11:54 PM
Is there a diagram somewhere that shows pin/plug numbers? My Ford was cake to install Nav on but not so sure about this Honda.
Posted By: BNLUIS
Date Posted: November 16, 2007 at 11:29 AM
Well you need to go to the pcm which is uner the hood, there is no other way that I see to get the VSS wire. It is in front of thge air filter next to the power steering fluid holder. Pin A29 Blue/White, will be between A28 WHITE/ green and A30 YELLOW /GREEN. As far as the back up lights you can find them up by the drivers fuse box, Green near the back up relay, obove fuse box. I just bought the same car for the wife, I am about to install the same system. The wire is in connector A when you look at the PCM is the first plug astarting on the left side( passanger side) Also if you are not doing a back up camera the don't bother connicting the wire, also if it seem to much work don't connect the VSS wire the pioneer unit will work without it , it will track the car trought gps.( not as accurate , but it will do, but you wont be able to use the VSD feature. ------------- Luis
Sound Waves
Posted By: cschoen
Date Posted: November 16, 2007 at 5:29 PM
When looking at the pcm there are 3 plugs, the one furthest to the left (passenger side)is the "A" connector right? The pin 29 is located on one of the edges of a row and it is all blue. Pin 28 has a white stripe. Is the odyssey you're working on a 2007? or am I looking at the wrong connector? By the way thanks for your help.
Posted By: cschoen
Date Posted: November 16, 2007 at 5:38 PM
Im sorry I meant to say pin 30 has a blue wire with a white stripe
Posted By: BNLUIS
Date Posted: November 16, 2007 at 6:45 PM
here is a diagram you will find these wire next to them look for the blue /white ------------- Luis
Sound Waves
Posted By: BNLUIS
Date Posted: November 16, 2007 at 6:49 PM
------------- Luis
Sound Waves
Posted By: INSTALLTECH323
Date Posted: November 16, 2007 at 11:21 PM
some odysseys do not have the vss wire , the slot is actualy open. what ive done in the past is strip'd the wire about an inch and pushed the wire in on that slot to make contact with the pin from the pcm and safely wired tied it. ------------- MECP CERTIFIED TECH
